oil pump question
Modular2v
3,222
23
99
oklahoma
since i have my 331 out for the winter i decided to put a new oil pump on just in case. I forget the torque specs on the pump to block bolts Anyone have them? I also was wondering if it matters which way the tab is turning on the pump to block gasket......i had the tab pointing toward the rotating assembly before:shrug:
yes. i don't know about you but i always kinda seem to torque that way. seems like i broke quite a few bolts torquing that way aswell. If you can get a new gasket put it in don't put in a ripped one because you are actually giving the oil another route to flow since you will have a gap the thickness of the gasket between the 2 surfaces if its a rip right through.
sounds like it should be ok. I guess you could put a little dab of form a gasket on it. I looked for a gasket sold on its own on the web and i couldn't find one. Would hate to buy a entire gasket kit for a 302 to get that 1 gasket.
i have to by an entire gasket kit anyway:D it is torn down to the short block right now
my heads are not o ringed no need for me. But every time i buy a kit usally comes with thos cheap head gaskets didn't realize you could get a kit with upgraded parts in it. Next time i strip the engine down i will look into that.
