oil pump shaft
  • Thread starter Thread starter mrf0rd
  • Start date Start date Jun 12, 2006
M
mrf0rd
64
Kent, WA
Jun 12, 2006
  • Jun 12, 2006
Is there a trick to keeping this straight up and down when installing the distributor? The shaft falls to one side and then doesn't let the distriburtor slide over the top.
Thanks in advance.
83Mustang427TT
162
  • Jun 12, 2006
Theres supposed to be a little washer on the shaft that holds it straight up ,you could always pick up the Ford racing shaft that fills the hole so it doesnt flop its round in the center then octagon on the ends to fit the dist. and oil pump
M
mrf0rd
64
Kent, WA
Jun 12, 2006
  • Jun 12, 2006
Thanks for the feedback. I finally got it to drop in after about 15 minutes. Of course it was off a bit so I had to pull it and redo it. Within 10 seconds the next time go figure.
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
P
Engine Swapping EFI distributor for carb distributor- shaft length is different
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 21, 2024
pindude80
P
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
