oil pump shaft
  • Thread starter Thread starter MattTheBat83
  • Start date Start date Jul 30, 2006
M
MattTheBat83
203
  • Jul 30, 2006
i tried to fit my oil pump shaft into the oil pump but it is about an inch and a half too short. am i doing something wrong?
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Jul 30, 2006
  • Jul 30, 2006
? where is the little metal st0p clip? it sh0uld fit right in there
TheBocSez
652
Converse, TX
Jul 30, 2006
  • Jul 30, 2006
Are you trying to slide it in from the top? It needs to go in from the bottom with the oil pump.
If thats not feasible now, some have removed the stop ring and siliconed it to the bottom of the distributor then slid it in, probably not the best way, and you risk it falling off and into the pan.
If at all possible, drop the pan and put it in the correct way.
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Jul 30, 2006
  • Jul 30, 2006
do it the right way and be done with it.........the person that had my car before me just drop it in and when i pulled the dizzy the shaft come out of the oil pump but didnt fall in the oil pan right away and then when i started it it bent it to hell and it took me forever to figured out wy i had no oil press.
i had a cherry picker mad it easier for me. i took the engine mount nuts all the way off and jacked the engine as far as i could. droped the oil pan(wont come all the way out) loosened the oil pump and wiggled the shaft to where its supose to be. took me a few hours cause almost every oil pan bolt was a diff size
good luck
M
MattTheBat83
203
  • Jul 30, 2006
yea i was trying to put in from the top... it was my first time and i couldn't find the hole
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Drivetrain 1987 Mustang notch drive questions
  • Shannonfox123
  • Apr 12, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
AeroCoupe
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
