oil quantity
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
may sound like a dumb question, but i like to play it safe. i just changed my oil about an hour ago. used royal purple & mobile1 filter. i know the owners maual calls for 6 quarts, so after the 5th bottle i checked to see where i was at, and i was right below the max. is this normal? engine was still pretty warm/ border line hot when i changed it, new oil was ambient temp obviously. the guage reads fine. should i check it again when it cools down or just leave it as is?
i know this sounds like a petty question but im getting ready to go on a road trip from little rock to harrisburg pa and i dont want to take any chances. this will be the first time my family sees the car, so i want it to be in prestine shape so i can take my dad for his first ride in a mustang. he's an old cheby guy. always tells me how he used to smoke old mustangs in his 68 chevelle 396 when he was my age. anyway, thanks guys.
Get a 6th quart and fill it up to the very max point on the dipstick, but no more. Fill it up to keep it at this point as it needs it. I know my car only requires 5qts and it reaches max full. Anymore, and it spits it out.
This is what I have been using since day one, 5 quarts w/filter change.
The following is taken from the alldata site:
2000 Ford Mustang GT V8-4.6L SOHC VIN X
Top - Vehicle
Specifications
. Capacity Specifications
Capacity Specifications - Oil
Notes Engine Oil 5 qt (US)
Note: With filter change
Copyright © 2005 ALLDATA LLC
Terms of Use
This is a pretty requent thing discussed...but Ford actually issued revised owners manuals for ceartin years but I can't remember wich it was..on my 96 it takes exactly 6 quarts to bring it to the MAX on the dipstick...need to remember that you need enough to fill the capacity of the oil pan plus the capacity of your filter..any extra will probably sit in the heads and help reduse dry start damage I would think..but heyto each his own...all I know is I use 6 quarts and If I drop to 5 1/2 quarts ( 1/2 a quart low) my low oil light stays lit all the time..
I'm pretty sure I did 6 with my last oil change right after Xmas, but I think mine eats oil. It sure doesn't burn it/leak so I'm not quite sure where it goes :shrug: Just fill it either a little below the max and check it often to see fi you need to add any:nice: But like everyone said, you do not want to overfill it. I know a girl who's bf changed her oil and filled it way too much- the spark plugs were swimming... :nonono:
After doing some research I found that the PCV on these cars is BAD about sucking oil from the valve covers into the intake and burning it off there..best wya I found to repair it cheap was a catch can from steeda or buy it at wally world cheaper..same as the little clear peice that you use with air tools to seperate oil from the air..
