  • SN95 4.6L Mustang Tech
oil question????
  • Thread starter Thread starter svo978
  • Start date Start date Oct 7, 2004
svo978
11
  • Oct 7, 2004
I have a 99 gt and no owners manual; how many quarts does it hold? I've called 5 different places, including FORD, and I have heard anywhere from 5 to 7 quarts. A local oil change place (American Lube Fast) said 6, and 7 if it had the towing package----- what the hell!!! A towing pakage on a mustang???? Please, someone with a owners manual give me a sane answer.
AdRock
521
South Texas
Oct 7, 2004
  • Oct 7, 2004
Once everything is drained and the new filter and drain plug are back in, just put in 5 qt's then start it up. Let ir run for about 30 seconds, shut it off and let it sit for a minute or so, then check the level. Add if it needs it and you'll know how much yours takes.
My '02 takes 5.5
maddogg545
91
NJ
Oct 8, 2004
  • Oct 8, 2004
Well the manual says to put in 5 but it all depends on what your engine says. My car is quite happy with 4 1/2 quarts. Just make sure you dont over fill your engine with oil. Thats a sure fire way to turn your engine into a pre-mature oil burrner!
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Oct 8, 2004
  • Oct 8, 2004
5 here. when i was working at ford, most of the 99-00 GTs took 5 quarts. With the 01+ GTs, we added 6.25 quarts and started the motor, then turned it off and checked the level. If needed, we added more
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Oct 8, 2004
  • Oct 8, 2004
5.5 for me
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Oct 8, 2004
  • Oct 8, 2004
My '02 takes 5.5
I agree with what he said.
When filling it up, be sure to put some oil in the oil filter as well. Fill it with as much as you can fit in it of the initial 5qts of oil. Once you start the car up and run it and then shut it down, add more if it needs it. Make sure you fill it up close to the max just to be on the safe side. Mine only takes 5qts and its completely full.
twogts4us
4,188
12
79
Dunedin, FL
Oct 8, 2004
  • Oct 8, 2004
5 for the 99-01, 6 for the 02-04
VOORHEES
Stangnet's "35th Limited Edition" VIN Guy
3,046
36
119
LaGrange, GA
Oct 8, 2004
  • Oct 8, 2004
Me too. 5 quarts
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
Upgrade Advice on an 89 GT Convertible NJ
  • SteakDad
  • Apr 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 18, 2025
limp
