  • SN95 4.6L Mustang Tech
Oil Question
  • Thread starter Thread starter Quik03GT
  • Start date Start date Jun 17, 2006
Q
Quik03GT
88
  • Jun 17, 2006
Hey guys, I was wondering if thinner oil generally increases consumption. I currently use Valvoline 5W20 non synthetic, and it uses about a 1/2 qt every 3k miles, sometimes a bit more. If I were to switch to 10W30 non synthetic, would that decrease oil consumption?
Thanks!
RandyStinchcomb
1,159
Randallstown, Md
Jun 17, 2006
  • Jun 17, 2006
no, stay wth what your using. asper FoMoCo, using a qt of oil between 800 & 1000 miles is NOT considered excessive
Crzyhrse
Seattle, WA
Jun 17, 2006
  • Jun 17, 2006
My Mach burns the least amount of oil of any of the 3 Mustangs I've owned. My '89 GT used 1qt. every 700 miles. My '93 GT used 1qt. every 1,300 miles, and my Mach uses 1qt. every 2,500 miles. I'm really happy with that.
Q
Quik03GT
88
  • Jun 17, 2006
Well, I guess I'm doing alright then. I've heard from some people that if you do alot of high rpm decellerating, this can increase consumption. Is there any truth to that?
BurningRubber
1,865
24
58
Jun 17, 2006
  • Jun 17, 2006
I dont get it, mine uses oil as well. Amost 3/4 a quart at the 3k mile mark... It doesnt smoke, no blowby in the intake, no oil fouled plugs...
the98stang
2,408
Clovis, CA
Jun 17, 2006
  • Jun 17, 2006
Guys, we have Ford engines. They're going to burn oil.
Don't worry about it.
M
miller766
33
  • Jun 18, 2006
I ended up running my car for almost 5000 miles once without changing my oil (definately wouldn't recommend doing that either) but I wasn't even 1/4 of a quart low when I changed it. So I guess I'm not really burning much oil in mine. But my 86 GT burned about a quart every 1000 miles or so.
sgarlic
3,085
Jun 18, 2006
  • Jun 18, 2006
To answer your original question, yes, generally thinner oil will more easily slip past worn rings, etc.
However, that would be thinner referring to the second part of the oil viscosity (i.e. 5w20 would slip past more than 5w30 or 5w40) .. the first number is the resistance to flow at cold temperatures, so it wouldn't make much of a difference running 5wX or 10wX, since the majority of the time is spent driving the car hot. In any case, 5w30 is fine year round, regardless of what carb people stuck back in the "my god damn 427 takes 20w50 quaker state, nothing else!" days may tell you.
My oil separator grabs around a teaspoon every 200 or so miles.
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Engine What engine oil are you running in your foxbody?
  • Mindseye007
  • Dec 9, 2023
  • 2 3 4
18K
Fox 5.0 Mustang Tech Jun 5, 2024
limp
V
Engine Antifreeze in oil
  • vinzo
  • Oct 9, 2024
Fox 5.0 Mustang Tech Oct 10, 2024
vinzo
V
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
