oil sensor?
  • Thread starter Thread starter tims 86
  • Start date Start date Jul 27, 2010
tims 86
187
pittsburgh,pa
Jul 27, 2010
  • Jul 27, 2010
this might sound like a dumb question but, the plug on the side of the oil pan is the low oil sensor? its leaking like crazy is there a way to replace it without removing the pan?
HISSIN50
34
129
Jul 28, 2010
  • Jul 28, 2010
It is. Some folks use a big bolt in the side of the pan when theirs starts to leak too much.
tims 86
187
pittsburgh,pa
Jul 28, 2010
  • Jul 28, 2010
i guess thats ok, i check the oil before i run it anyway. do you know what size bolt it is?
H
Haus
408
  • Jul 28, 2010
I cleaned up the hole and put a high temp sealant around it and no problems since.
HISSIN50
34
129
Jul 28, 2010
  • Jul 28, 2010
It's been posted in here before but I don't know it off the top of my head.
L
Lawbreaker5.0
543
Texas
Jul 28, 2010
  • Jul 28, 2010
this would probably fix it
1984-96 Mustang 5.0L/4.6L Low Oil Level Sensor Gasket by Ford at LRS - Same Day Shipping!
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,115
224
Massachusetts
Jul 28, 2010
  • Jul 28, 2010
There is a gasket.
I replaced mine and it still leaks from the sensor itself. I need to wait til next oil change to pull it out and inspect. I might unplug it and stick a bolt in. I drive maybe 500 miles per year between changes...so The risk is low.
Btw, you will need tom drain the oil pan before removing it.
tims 86
187
pittsburgh,pa
Jul 29, 2010
  • Jul 29, 2010
its more of a pain in the butt cleaning the oil up more than anything, im not sure if its worth the money for a new sensor and gasket. i guess next oil change i will probably stick a bolt in it.
H
Haus
408
  • Jul 30, 2010
You should try the high temp sealant. hasnt leaked since I sealed it. that way you can still use the sensor
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jul 31, 2010
#10
  • Jul 31, 2010
  • #10
20mm 1.5 pitch drain plug is what you need should you go that route.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
Engine Cheapy Fox body 7qt oil pans?
  • rednotch
  • Mar 25, 2025
Fox 5.0 Mustang Tech Apr 15, 2025
08GT500
