I just got my car running after installing my supercharger. I took it out for a ride to see if everything is ok. I was sitting in traffic and it was like 95 out side. The oil temp got up to almost 260. Is this some thing that i should be worried about? The blower (Vortech SQ) got very hot too. I burnt my hand when I touched it. I know they get hot but will it get hot so hot that it burns your hand? Should i invest in a oil cooler? If so witch one should I use? Thanks for the help!
. dont drive it anymore without a supercharger base tune at least and dont get into any boost or you can kiss your engine goodbye. the blower will only create so much heat. it wont go over around 190. even though you kept it in vacume your still probably running lean witch is causing your under hood temps to go up.
