  • 1994 - 1995 Specific Tech
Ok, another suspension question
  • Thread starter Thread starter 1987Rock
  • Start date Start date Dec 28, 2007
1987Rock
114
  • Dec 28, 2007
I've currently got 2" Dropzone springs on my car with the original shocks/struts. Could the ride be so bad because the original shocks are bottoming out?
Does anybody know of some good, affordable drop shocks? Everything I've seen besides Tokico's aren't for dropped cars.
I plan on getting some Eibach pro kit springs for a 1"-1.5" drop, so I'm looking for some shocks for that drop, but that might work for the 2" until I can buy the new springs. Thanks
HGFireHazard
460
Michigan
Dec 28, 2007
  • Dec 28, 2007
If I'm not mistaken we can run shocks/struts from the fox bodies (87-93) which are 1" shorter than ours. This along with the design of a good set of shocks/struts should give you the result you're looking for.
I'm not 100%, but I'm pretty darn sure, so if someone else could confirm that would be helpful.
earleys94gt
1,223
Ashley, Ohio
Dec 28, 2007
  • Dec 28, 2007
With a 2" drop, the shocks are most certainly bottoming out.
If you plan on getting the Eibach Pro-Kit, I am almost certain they sell spring/shock combo kits for the Pro-Kit.
It will cost more than just the springs alone, but might be a route worth checking.
1987Rock
114
  • Dec 30, 2007
Yeah, I know they make struts/shocks to go with them, but they are fairly expensive. I like the KYB Gr2 struts and Gas A Just shocks, but I don't think they make them for a dropped car.
That's interesting about the fox body shocks, I've heard that before, but don't know if it's true.
Yobi1Kanobi
559
  • Dec 31, 2007
it is true for our cars when lowered you may use the 87-93 strut and shocks that give you some more travel. the fox has naturally a lower ride hieght than our car. i just did all the research for new struts for mine.
1987Rock
114
  • Jan 2, 2008
Cool, sounds like that's the way to go.
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
