OK I got some codes from my computer
I got a 10 11 and a 67. 67 is supposed to be a Nuetral safety swith. I dont know where that is. 11 is system checks ok. Well good. 10 is ? I cant find anywhere of what 10 means. In books or the internet. So my questions are what is code 10 and where is the nuetral safety switch. Im sure its on the tranny some where. So here is what I'm driving 1986 mercury capri 5.0 manual trans. All stock except for Flowmasters and K&N air filter. :shrug: By the way you guys are great.:nice: :banana:
No code 10. That's a Phantom flash that the computer gets on startup.
Code 67 - clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. This code may prevent you from running the Key On Engine On tests. You can generally ignore this code, since it has no effect on engine performance.
Items 6 & 7 point to the neutral safety switch on the T5 in the following drawing:
attachment.php
If like an aero fox, 67 is from having the car in gear or the AC selector turned on while pulling codes.
You might be seeing the quick flash for code readers - dont pay it any mind.
Good luck.
There is nothing wrong with your EFI setup. You have some basic mechanical problems or a tune up need. Do some diagnostic work like a compression test & a vacuum test to rule out any mechanical problems. Fix what you find. Then do a full tune up, plugs, cap, rotor, wires, fuel & air filters. Set the timing with a timing light at 14 degress. You'll be suprized how good it runs, and all for much less time & $$$ than any carb conversion.
mercurycapri said:
Well car runs like crap. Hell with it. Its going carburated.
I've thought about that in the past when my EFI was making me unhappy. But... Getting your EFI all straightened out will be a LOT less work that converting to a carb, and it will run a lot better and be a better driver with the EFI.
If you have some sort of mechanical problem, the switch to a carb won't help that. Just find out the problem and fix the EFI, you'll be a lot happier.
Jeff
