  • 1994 - 1995 Specific Tech
Ok im finally doing my gears. Lets make sure I have everything I need.
  • Thread starter Thread starter The Green GT
  • Start date Start date Dec 5, 2006
First Prev 2 of 2
drakesdad
961
Oregon OHIO
Dec 6, 2006
#21
  • Dec 6, 2006
  • #21
RIO5.0 said:
Thought I did a delete to my post as I seen he bought the install kit...I figured the seals would be in there??
10-4 on the freakin reluctors to..never have good luck with those myself...
Well at least I only had to remove 1.......so I only broke one....
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Dec 6, 2006
#22
  • Dec 6, 2006
  • #22
So the seals are NOT in the istall kit?
drakesdad
961
Oregon OHIO
Dec 6, 2006
#23
  • Dec 6, 2006
  • #23
I am not sure Eric....I did not buy the kit...............I got Motive gear and went to the dealer for the pinion bearing, seals, crush sleave etc....
R
red95gtconvert
382
Ponca city, OK
Dec 6, 2006
#24
  • Dec 6, 2006
  • #24
I must of got lucky when I installed my gears, I didn't break any
sage2k
645
Baton Rouge, LA
Dec 7, 2006
#25
  • Dec 7, 2006
  • #25
3.73s + 2k rpm = 60mph
1.5k rpm = 45mph
go from there
Stanger007
2,015
Baton Rouge, LA
Dec 7, 2006
#26
  • Dec 7, 2006
  • #26
You CAN use the Speedcal with whatever speed sensor gear you have.
Here's what I bought and brought to the Mustang shop to have my rearend installed:
  • Traction Lok Rebuild FMS-M-4700-B
  • Royal Purple Gear Oil: RPO-RP01300
  • Ring Pinion Install Kit FMS-M-4210-C (If you are getting the Superior axles you may can get this kit w/out axle bearings and seals for cheaper since the superior kit comes with them?)
  • ...and the 4.10s
Wish I would have done this... (hindsight is 20-20)
28-spline Superior Axles SAG-EV83-28
Oh well, that just means I'll have to upgrade to a 31-spline unit in the future.
Wes
The Green GT
1,269
Louisiana
Dec 7, 2006
#27
  • Dec 7, 2006
  • #27
How much oil will I need?
RIO5.0
6,892
N.H.
Dec 7, 2006
#28
  • Dec 7, 2006
  • #28
Your all set...Your link shows the seals in the kit...
drakesdad
961
Oregon OHIO
Dec 7, 2006
#29
  • Dec 7, 2006
  • #29
If I remember I bought two bottles of 80/90..........
TheDamned
"I am Canadian and Damned for it!"
Jul 22, 2003
457
Montréal, Québec, Canada
Dec 8, 2006
#30
  • Dec 8, 2006
  • #30
Don't forget the speedo gear... good luck with the install, i got raped by a mech who didnt knew anything about gear and lost 600$ to him.
The Green GT
1,269
Louisiana
Dec 13, 2006
#31
  • Dec 13, 2006
  • #31
So its the 23 tooth or 21 tooth speedo gear?
And do i need the retaining clip? Ill prolly get it since its like $2
TheDamned
Jul 22, 2003
457
Dec 13, 2006
#32
  • Dec 13, 2006
  • #32
I don't recall but I think it goes by colour tho, if yes it's the white one.
The Green GT
1,269
Louisiana
Dec 13, 2006
#33
  • Dec 13, 2006
  • #33
50resto dosent have any whiter ones (that I see) and they dont have 23 tooth ones. That why Im confused. I always though it was 23 tooth and they dont even have them.
bill302
2,131
alabama,gadsden
Dec 13, 2006
#34
  • Dec 13, 2006
  • #34
yes the white 23 tooth speedo gear click on link below to buy the gear...
http://motors.search.ebay.com/searc...=compare&copagenum=1&coentrypage=search&fgtp=
The Green GT
1,269
Louisiana
Dec 13, 2006
#35
  • Dec 13, 2006
  • #35
Thanks.
bill302
2,131
alabama,gadsden
Dec 14, 2006
#36
  • Dec 14, 2006
  • #36
when i installed my gears i also replaced the wheel bearings and seals .its easier to do it now that later and click on links below for parts...you don't have to change them but its a good idea ,talk to your mechanic about it i bet he will recommend it most autoparts stores keep these in stock..you will need 2 each in the links below..
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=BCA&mfrpartnumber=5707&parttype=186&ptset=A
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=SKF&mfrpartnumber=13992&parttype=293&ptset=A
Stanger007
2,015
Baton Rouge, LA
Dec 14, 2006
#37
  • Dec 14, 2006
  • #37
From my notes:
Jeep Part #j3167393 3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy.)
The Green GT
1,269
Louisiana
Dec 14, 2006
#38
  • Dec 14, 2006
  • #38
Stanger007 said:
From my notes:
Im pretty sure its a 7 tooth drive gear. Thats what they say on 50resto atleast.
Stanger007
2,015
Baton Rouge, LA
Dec 14, 2006
#39
  • Dec 14, 2006
  • #39
Check this out:
http://forums.stangnet.com/showpost.php?p=6166445&postcount=2
The Green GT
1,269
Louisiana
Dec 14, 2006
#40
  • Dec 14, 2006
  • #40
Stanger007 said:
Check this out:
Ok ,the combonation they were selling on 50resto was a 21 tooth and a 7 tooth drive gear.
Thanks.
First Prev 2 of 2
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
So confirming what I need to do to put a '88 CV 302/AOD in my '65 A-code.
  • 1320stang
  • Apr 19, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2023
1320stang
My 93 4v Fox
  • OffspringChaos
  • Aug 30, 2023
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2024
bird_dog0347
mustang gt rear end/differential rebuild cost vs doing it myself
  • sharpright
  • Nov 4, 2020
15K
1996 - 2004 SN95 Mustang -General/Talk- Jun 22, 2021
Mustang5L5
