  • 1994 - 1995 Specific Tech
Ok need some Nitrous Advice...
  • Thread starter Thread starter GTA_V6_Mustang
  • Start date Start date Mar 15, 2010
First Prev 2 of 2
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,302
1,645
214
Acworth, GA
Mar 17, 2010
#21
  • Mar 17, 2010
  • #21
Dry kits are better, end of discussion. He has his heart set on a dry kit.
Kurt
Tanus
847
A to the Z
Mar 18, 2010
#22
  • Mar 18, 2010
  • #22
how is a dry kit better?
will a 100hp dry kit make more power than a 100 wet kit?...... yes, definatly, lean runs strong (oddly)
Is a 100 dry kit safer than a 100 wet kit? hell no
revhead347
20+ Year Stangneter
Jun 14, 2004
9,302
1,645
214
Acworth, GA
Mar 18, 2010
#23
  • Mar 18, 2010
  • #23
Just to be clear, in the beginning, god loved the world, so he gave us wet kits. Then NOS designed the dry nitrous kit, because wet kits were blowing up the new EFI long runner intakes. If there was no danger in a wet kit, the dry kit would have never been designed in the first place. So, the motivation was safety. The byproduct was inherit better fuel atomization associated with a dry kit.
Even so, why do you strongly recommend spending money converting a working dry kit into a wet kit? The dry kit works fine the way it is. Why waste the cash.
Kurt
Tanus
847
A to the Z
Mar 18, 2010
#24
  • Mar 18, 2010
  • #24
the dry kit is sold cause its cheaper and eaiser to install.
look at any kit over 150hp shot, all wet kits
legalize420
1,541
South Florida
Mar 18, 2010
#25
  • Mar 18, 2010
  • #25
not true. you can go much higher than 150 on a dry kit but it cost MORE than a wet kit. you just need a custom setup as i described above. its really a matter of opinion. there is no one is better than the other. both have their pros and cons.
GTA_V6_Mustang
1,326
Miami, FL
Mar 18, 2010
#26
  • Mar 18, 2010
  • #26
didnt mean to start an argument here, lol. And hollywood didnt know sorry. But yeah I got the edelbrock pump from cjpony because they had a special. For every 100 you spend 30 gift card, lol. I did think about the wet kit but was scared of blowing the manifold off like people said.
GTA_V6_Mustang
1,326
Miami, FL
Mar 18, 2010
#27
  • Mar 18, 2010
  • #27
Funny enough a diesel runs stronger when richer, other side of the spectrum. lol
revhead347
20+ Year Stangneter
Jun 14, 2004
9,302
1,645
214
Acworth, GA
Mar 18, 2010
#28
  • Mar 18, 2010
  • #28
The dry kits don't run lean. That's a myth. You can adjust the fuel mixture just like on a wet kit by jetting it.
Kurt
revhead347
20+ Year Stangneter
Jun 14, 2004
9,302
1,645
214
Acworth, GA
Mar 18, 2010
#29
  • Mar 18, 2010
  • #29
Installation is about the same. The dry kit has more parts, and costs more to make. Wet kits worked fine for years with carbs. When the long runner intakes came in with EFI, engines started puddling fuel up in the intake with a wet kit. You can spray up to about 225 on a dry kit with some custom work. After that, you just run out of fuel pressure. You can't spray any more than 225 through a single nozzle wet kit anyway.
Kurt
legalize420
1,541
South Florida
Mar 18, 2010
#30
  • Mar 18, 2010
  • #30
Kurt
if you ditch the nitrous regulator and go with a single solenoid you can run more than 225. that is if you have a block that can handle it and injectors that can supply the fuel. its all in the tune. mainly the maf transfer.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,302
1,645
214
Acworth, GA
Mar 18, 2010
#31
  • Mar 18, 2010
  • #31
Yeah, you can just run two really big solenoids too. I've never heard of going more than 225, but that's an interesting concept. I think there comes a time when you just have to step up to a fogger or plate to keep the system more realistic.
Kurt
Tanus
847
A to the Z
Mar 18, 2010
#32
  • Mar 18, 2010
  • #32
Kurt
there is no point arguing opinions, wet kit is more expensive than a dry kit-fact. wet kit is basicly a dry kit minus that regulator thing that jumps up the fuel pressure, but also has a fuel soliniod and fuel lines.
FYI- Ive installed and used both
revhead347
20+ Year Stangneter
Jun 14, 2004
9,302
1,645
214
Acworth, GA
Mar 18, 2010
#33
  • Mar 18, 2010
  • #33
The dry kit comes with two solenoids plus the fuel pressure booster, the wet kit just comes with 2 solenoids. That's more components in the kit. I would assume that more components means more cost.
Kurt
hollywoodstang
1,095
Mar 19, 2010
#34
  • Mar 19, 2010
  • #34
GTA bought my kit today, i give him the brand new newer style bottle and the kit brand new in package and the billet adjustable bracket, he will be doing 75hp shot to start,
He did researched it found out that 'Dry' kit fit his need more then the 'Wet' kit, and i also told him that later on he can switch to "wet" kit from dry if he choose to. so there it goes,
There are always pro's and con's with everything and i think he made a smart decision for himself, i also run dry kit 150hp and i do not have any problem, I run it twice or three times every-week at local 1/8th mile track,
9
96darkhorse
693
wilmington, california
Mar 19, 2010
#35
  • Mar 19, 2010
  • #35
legalize420 said:
most people think you need to step up on the injector size for a dry kit but thats not true in most cases. the typical off the shelf dry kit runs on elevated pressure at the fuel rail. obviously the increased pressure makes the injector spray more than it would at stock pressure. therefore you chose your injector based on your N/A requirements. the only time you would need to run larger injectors on a dry kit is if you have a custom kit that you run on stock fuel pressure. in that case you would much larger injectors than required for your N/A requirements along with a custom nitrous tune. it can be done but its not very common. just get the pump and you will be good to go.
thats right....i was running a zex dry kit 100 shot on top of my 323/341 hci motor on 24lbs, no prob
GTA_V6_Mustang
1,326
Miami, FL
Mar 19, 2010
#36
  • Mar 19, 2010
  • #36
Well thanks to everyone for all the great input as always. Good info here. As always stangnet never lets me down!
GTA_V6_Mustang
1,326
Miami, FL
Mar 19, 2010
#37
  • Mar 19, 2010
  • #37
Oh and figured I would add this random peice of info. For those who doubt the capability of the stock fuel pump Im at 320RWHP with 24lber's and no problems.
First Prev 2 of 2
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 26, 2025
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
