ok...pulled codes on car finnally.....
How were the O2's cleaned?
Have you tripped the inertia switch lately? The code can mean that the fuel pump lost power for a split second when it should not have.
Good luck.
That's new to me. The only method I've ever heard of working is heating the sensor to clean it off. This can be done by removing the sensor and hitting it with a torch, or (in the older days), by introducing a huge vac leak. This would heat EGT's up and help burn deposits off the Lambda sensor.
You can check them for switching and amplitude (seeing it range from ~0.1-1.0 volts, a couple times a second).
Good luck.
