Ok results on surging problem...
  • Thread starter Thread starter MY 85 GT
  • Start date Start date Mar 20, 2008
MY 85 GT
1,852
208
104
New Jersey
Mar 20, 2008
  • Mar 20, 2008
Ok so yesterday i went home in the pouring rain and i wanted to play around with the car so i did....lol....I got a little wet but it was worth it...Anyways I was talking to my Father and he told me try advancing the timing instead and see what happens...so i did i moved it a little advanced took if for a ride and it seemed almost all gone....I also talked to Edelbrock tech line they told me to put in a different step up springs under the metering rods i did that too...AND WOW....does this car haul now....no surge..no miss no nothing just tire breaking speed....LOL...So my question why did i have to advance my timing so much for it to run so well????I mean when i looked with a timing light it was about 15 degress....I must have advacned it to like say 20 degress could that have been off or something????
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Mar 20, 2008
  • Mar 20, 2008
and you are sure you have everything set up right? timing light on #1 plug....etc?
that does seem kinda odd to me too. and are you sure your dizzy is place correctly. number one cylinder T.D.C on the compression stroke distributor on #1 on the rotor?
im sure you have all of this correct but it never hurts to check
MY 85 GT
1,852
208
104
New Jersey
Mar 20, 2008
  • Mar 20, 2008
As far as i know i had the timing light on it the 1st time and yes i had the light on plug wire number 1 maybe the Dizzy is off a little or something because i think it has alot of intial timing but it seems to run great this way...very responsive...no pinging..car starts right up when hot ...i too am confused....the carb takes an adjustment nice....i dont know weird no????but the surging is gone....at least.....I now when i bolt the blower up i cant use vac advance anyways so i need a good intial timng so i should be ok and im also installing an A/F gauge to so i can really make sure how im running with the blower.....
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
