Ok, someone check this over for me please
c l stang
12
Maryland
this is the list that i have come up with for the t-5 swap i am planning on doing.
t-5 WC
10" diaphragm stlye 10 spline clutch
stock flywheel 157, 28 oz
5.0 bell housing and arm
t-5 crossmember
cable clutch kit
drive shaft yoke
how does this look? I have a clutch pedel. i am converting from a c-4 auto
thanks,
lee
you need to check that your stock flywheel is drilled for the late-model clutch/PP. It may not be.
Also, you will need the 5.0 block plate for your bellhousing so your starter will index correctly.
What about a shifter?
