  • 1994 - 1995 Specific Tech
ok...still nothing.....
  • Thread starter Thread starter MI95Cobra
  • Start date Start date Jun 11, 2007
MI95Cobra
451
Oklahoma City
Jun 11, 2007
  • Jun 11, 2007
well i found a few messed up spark plug wires...so i bought s new set and still nothin...it turns over faster but still backfires....i'm running out of ideas...should i try and reset the dizzy again??? also i think i'm going to just leave it alone...buy the new heads i want, put them on and have a mechanic fix the problem.... ...i also bought an obd1 diagnostic scanner...think that could tell me the problem???
jimmy
Stanger007
2,015
Baton Rouge, LA
Jun 11, 2007
  • Jun 11, 2007
Sounds like Grady's advice he gave you earlier might be it - if you are backfiring either a valve is hanging open or your distributor is off?
I didn't read all the other threads but did you try a compression or leak down test?
Wes
R
red95gtconvert
382
Ponca city, OK
Jun 11, 2007
  • Jun 11, 2007
This is definately the hard way to do it but you've already had alot of problems anyway so... Why not restab the dizzy one tooth clockwise and try starting it, if doen't start just keep repeating the process until it does. It may take quite a few trys but you will find the right spot eventually. I've done this before and had the car running within 15 minutes. Good luck.
On a side note I will be in OKC thursday and can possibly come by and take a look at it with you if you want.
GTJake
3,049
Ann Arbor, MI
Jun 11, 2007
  • Jun 11, 2007
Eliminate the fact that it could be the dizzy first. I don't know how you've been doing it before, but here's what I do.
Take out the #1 plug put your finger over the hole and crank it over slowly until you see the balancer coming up on 0* BTDC. Then when you're close, take a breaker bar and crank the motor over until it's at exactly 0* BTDC. Stab the dizzy in so it's pointing directly at the #1 terminal. Put the hold down clamp on the dizzy lightly just so it doesn't move too much. Pull the spout and have a buddy start the car and you stand next to the motor and get ready to twist the dizzy clockwise to advance the timing a hair.
Jake
MI95Cobra
451
Oklahoma City
Jun 11, 2007
  • Jun 11, 2007
i thought about pulling the distributor and checking the gear on the bottom and restabbing the dizzy...i'll let you know how it turns out....
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 12, 2007
  • Jun 12, 2007
jimmy
Jimmy
I've given some thought about your ordeal since you installed the heads that have been cut an unknown amount.
Here are the basic things that need to be checked with the valve train
1) Rocker tip travel distance over the tip of the valve
2) Position of #1 to see if it is centered over the tip of the valve
3) Spring coil bind
4) Clearance between top of retainer and bottom of rocker
5) Correct lifter pre load
You can get all specifics of 1-5 on the big cam folks sites btw
While all 5 things need to be correct for proper reliable operation ......
I got a simple test you might wanna do to give you an idea of
what is going on with things.
Since you got cut heads ... it is #5 that I suspect is causing you the
biggest problem.
You said in another thread you had no compression. I suspect your
pre load is too deep in the lifter and holding the valves off their
seats.
Before you buy new heads or spend a lot of money for a mechanic ......
Consider this as a test to check things out.
I got my mic out and checked several of the thinnest washers I had
laying around the garage. I found the range to be 40 to 50 thou
which is close enough for what we wanna do.
Instead of buying a shim kit you could just place a washer on each
side of the ped bolt for a temporary shim to preform our little test.
If you find you then got compression ........
the pr's could be too long
btw ... this has nothing to do with dizzy timing and is valid even
if the dizzy is not installed in the motor.
One last thing here is this ............
This test is only to check things ... don't start the motor
Grady
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
  • brandyn200
  • Jun 20, 2026
AeroCoupe
A
ECT sensor wires gone?? HELP
  • archer886
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 8, 2025
Mustang5L5
