well i found a few messed up spark plug wires...so i bought s new set and still nothin...it turns over faster but still backfires....i'm running out of ideas...should i try and reset the dizzy again??? also i think i'm going to just leave it alone...buy the new heads i want, put them on and have a mechanic fix the problem....
...i also bought an obd1 diagnostic scanner...think that could tell me the problem???
jimmy
Jimmy
I've given some thought about your ordeal since you installed the heads that have been cut an unknown amount.
Here are the basic things that need to be checked with the valve train
1) Rocker tip travel distance over the tip of the valve
2) Position of #1 to see if it is centered over the tip of the valve
3) Spring coil bind
4) Clearance between top of retainer and bottom of rocker
5) Correct lifter pre load
You can get all specifics of 1-5 on the big cam folks sites btw
While all 5 things need to be correct for proper reliable operation ......
I got a simple test you might wanna do to give you an idea of
what is going on with things.
Since you got cut heads ... it is #5 that I suspect is causing you the
biggest problem.
You said in another thread you had no compression. I suspect your
pre load is too deep in the lifter and holding the valves off their
seats.
Before you buy new heads or spend a lot of money for a mechanic ......
Consider this as a test to check things out.
I got my mic out and checked several of the thinnest washers I had
laying around the garage. I found the range to be 40 to 50 thou
which is close enough for what we wanna do.
Instead of buying a shim kit you could just place a washer on each
side of the ped bolt for a temporary shim to preform our little test.
If you find you then got compression ........
the pr's could be too long
btw ... this has nothing to do with dizzy timing and is valid even
if the dizzy is not installed in the motor.
One last thing here is this ............
This test is only to check things ... don't start the motor
Grady
