ok to sand blast pot metal??
im not sure about using sand, but you could probably get away with using other media like walnut shells or plastic beads instead of sand.
since the pieces arent very big you can also go with a die grinder with some sand paper or a scotch brite pad.
I had exellent results using Caswell Plating products to fill the pits after bead blasting with small particle walnut shells. I did the A/C console bezel and the 2 rear top mouldings on my 65 vert and had a 100% fill. Also i repaired a small crack of about 1/2" on the headlamp door in my 66. The trick is not to over polish the areas and to clean all pitted holes very well by drilling them just enough to remove the corrosion. Here is the link to the product.
Caswell Inc. - Solder-It Products
