out goes the 04' Cobra, in goes the 93 LX H/B
I have been a member of this forum for many years now and had a 2000 GT, then sold for a 2004 Cobra, now sold that and now I just purchased a 1993 LX. Always loved the older 5.0's and this was too good of a deal to pass up. Mods listed below with a short video also....motor is built for boost and I am thinking ProCharger or Vortech down the road. Let me know what you guys think. Car has run an 12.5 @ 111mph pre heads/intake and new MSD stuff, made 310/335 before the TW heads and intake went on and was not really tuned. I am thinking with a good tune maybe 350/375 and possibly get in the 11's.
Oh and the car weighs a tick less than 3000lbs. with a 1/4 tank of fuel.
1993 LX H/B
*Engine:
-9K on new motor, installed June 11'th, 2004
-306, balanced & blueprinted, started with new FRPP Cobra shortblock
-Trick Flow Twisted Wedge Heads (light mods to heads, can give details)
-Trick Flow hardened pushrods
-FRPP lifters
-1.6 FRPP roller rockers
-F-303 Cam
-Trick Flow Track Heat Intake (polished)
-24# injectors, Granatelli 76mm MAF, Kirban Adjastable regulator
-Edelbrock 70mm TB & Spacer (polished)
-C&L TrueFlow Intake Tube (polished) & K&N 12" filter
-March Underdrive pullies, All March polished pully covers & alt. fan, polished stock tensioner w/ UPR Billit idler pully
-140 amp Powermaster Alternator (6 months old, one wire)
-MSD 6a, mounted on custom polished bracket, MSD cap & rotor, FRPP 9mm Ignition Wires, Accel Ignition Module, MSD Ignition Coil
-New (not junkyard) from Ford electric fan for '98 Taurus V-6
-Smog Pump Eliminated, along with all other emmisions related items
-ARP Bolts EVERYWHERE!
-FRPP 4 Core Aluminum Radiator
-Griffen Radiator Cap
-160* Thermostat
*Exhaust:
-BBK Shorty Equal Length headers
-MAC O/R H-pipe
-MAC Cat-Back
*Suspension:
springs, shocks & struts, rear lower control arms were all replaced and are new since March '05.
brakes, 5 lug conversion, and new rear axle since about 800 miles ago!
-Steeda Sport Springs
-Tokiko Illumina 5 way adjustable struts & shocks
-Steeda Aluminum Rear Lower Control Arms
-Metco Solid Rear Upper Control Arms
-Steeda Front & Rear Sway bars w/ new bushings & endlinks
-MM Full Length Subframe connectors with X-braces
-RNH Racing Upper/ Lower Torque Box Reinforcement Kit
-MAC Camber Plates
-New spring isolators
-'94 Mustang Spindles
-'94 Mustang Ball joints (NO SPACERS USED IN CONVERSION)
-Stainless Steel Brake Lines
-Powerstop X-Drilled 13" front rotors
-Bullit Mustang Twin Piston PBR Callipers w/ Hawk Pads
-ALL bushings have been replaced
-Battery Relocation Kit (Taylor Aluminum box, polished, no outside cutoff switch!)
*Drivetrain:
-Liberty Custom 5 speed (about 1.5 years old, maybe 7K on it)
-Spec II Clutch Assembly (new with motor), factory flywheel (new with motor)
-Pro 5.0 Shifter
-FRPP Adjustable Clutch Cable & Alum. Steeda Quadrant
-FRPP Aluminum Driveshaft
-3.73 Gears
-FRPP 31 Spline Diff (installed 3 weeks ago with axles, seals, bearings, ect. 600 break-in miles on rear since then)
-Superior 31 Spline Axles (5 lug)
-Redline Synthetic 75W90 Gear Oil and Motorcraft Friction Modifier Used
-MAC Rear Stud Girdle
*Interior:
-2003 Cobra Seats (Black w/ gray suade, all power options work!)
-New Black Carpet throughout
-Custom Rear Seat delete carpeted in black
-'89 GT door panels
-MAC white faced gauge cluster
-Auto Meter Gauge Cage w/ Phantom Oil & Water, (light up green to match dash)
-Auto Meter Phantom Monster Tach w/ shift light & memory
-Cowlgaugeconcepts custom gauge cowl panel with Auto Meter Phantom Volt & Feul Pressure Guages
-Steeda Billet Pedals
-2003 Cobra Shift Knob (5 speed pattern)
-Custom leather boot over E-brake handle
-All options work! Ashtray door works perfect! Console lid also latches.
-Sony CD deck with 10 disk Sony Changer and Kenwood 380 Watt amp under rear seat delete, Polk Audio Speakers
-Best Fox interior you will see!
*Exterior:
-2001 Cobra-style wheels (factory polished, actually these came new on a 2004 GT, but are the same wheel)
-Projector Headlight/ Diamond clear markers (these do not leak, and are lined up perfectly. Projector bulbs are wired to a stock GT foglight switch
-Alot of chrome / polished items under hood. Some custom one-off parts too.
-IST Hood Lifters
short video
http://s113.photobucket.com/albums/n210/Dreddstang/?action=view¤t=LXVidforward.flv
Oh and the car weighs a tick less than 3000lbs. with a 1/4 tank of fuel.1993 LX H/B
*Engine:
-FRPP lifters
-F-303 Cam
-160* Thermostat
*Exhaust:
-MAC O/R H-pipe
-MAC Cat-Back
*Suspension:
-MAC Camber Plates
*Drivetrain:
-Pro 5.0 Shifter
-3.73 Gears
*Interior:
-'89 GT door panels
*Exterior:
-IST Hood Lifters
short video
