older 302 cam question
  • Thread starter Thread starter slow93
  • Start date Start date Dec 10, 2006
slow93
406
  • Dec 10, 2006
i have a 78 f150 that im about to put a cam and lifter kit in and a friend of mine has a cam that i am considering..it is 525 lift 292 duration. My question is will this cam work with the other stock components(stockheads,rods,crank,pistons,pushrods etc.)..any info would be appriciated
jtfairlane
468
  • Dec 10, 2006
A .525" lift will NOT work with the stock springs (single with no damper) on a '78 302. If you upgrade the springs on your stock heads to match the cam, you should be fine.
Double check the firing order on the cam. Cams for real early small block ford's have a 1-5-4-2-6-3-7-8 firing order, cams for later model 302s have a 1-3-7-2-6-5-4-8 firing order.
I don't understand why your asking about whether the cam will work with your stock crank rods and pistons. As long as you have adequate piston to valve clearance with a new cam, that should be all that matters.
I would not reuse the stock pushrods.
slow93
406
  • Dec 10, 2006
i never even thought about the valve springs. ive been racing for a long time but im just getting into the building aspect..how much are the stock springs good for?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 11, 2006
  • Dec 11, 2006
If those are the original springs, they are probably worn and weak. You should plan on replacing them to prevent high RPM piston to valve contact.
JChalfan
551
Bellevue, WA
Dec 11, 2006
  • Dec 11, 2006
I was under the impression that the firing order change happened when Ford switched to roller cams. I beleive any 302 flat tappet cam should have the older firing order. Old 351w's had the newer firing order though if I remember right.
Someone correct me if I'm wrong...
Jeff
jtfairlane
468
  • Dec 11, 2006
Jeff
Yeah, I couldn't remember when the change occured off the top of my head, so I thought better to recommend checking versus not checking. No harm in double checking anyway!
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine 302 production block selection
  • FastDriver
  • May 19, 2024
  • 2 3
8K
Fox 5.0 Mustang Tech Jul 1, 2025
FastDriver
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
Bought an engine for my project
  • 2stroke1971
  • Jul 7, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2024
limp
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
