  • 2005 - 2009 Specific Tech
On a budget... Unfortunately
  • Thread starter Thread starter echo4joe
  • Start date Start date Nov 25, 2009
1 of 2 Next Last
E
echo4joe
Beaufort, SC
Nov 25, 2009
  • Nov 25, 2009
With a completly stock 07 GT, I will have a budget of around 4K at tax season. What will give me the most BANG for the buck to push me back into the seat? Not a huge fan of NO2... Not sure why. Im looking for possibly a remanufactured turbo or supercharger? Any suggestions?
walter
1,054
Houston TX
Nov 25, 2009
  • Nov 25, 2009
I don't want to sound rude but the #1 question as usual...
What is your goal for the car?
If you answer that your suggestions will be much more specific.
E
echo4joe
Beaufort, SC
Nov 26, 2009
  • Nov 26, 2009
I'm not looking for an 11 sec. car... But I want to give a 50,000 car a run for its money on weekend cruises. I guess you could say a sleeper car. I'm not interested in track days or drag strips, but I do want to pee in a corvette owners cheerios! Does that make sence for a goal?
chad9350
248
Lake Charles, LA
Nov 26, 2009
  • Nov 26, 2009
Turbo done right, over 10K w/ tuning, gauges, etc...
CAI, dyno tune, 4.10 gears, LT headers
THAT's about 3K+ right now...
Take your time... these are not fox bodies... they are $$$!
wusthof
192
BC, Canada
Nov 26, 2009
  • Nov 26, 2009
I would kill for your budget dude! I'm on a budget for gas and oil changes !
stanmckinney
1,188
Nov 27, 2009
  • Nov 27, 2009
For real, I would love to be looking at $4,000 come tax time. I just hope I don't end up owning that.
ct07gt
377
  • Nov 27, 2009
I would agree with the CAI and tune and 4.10 gears but I think a suspension upgrade would be a better idea instead of long tubes. The headers are usually a pain to install and aren't cheap to begin with. A suspension is something that most people can install themselves with not much trouble.
As far as beating Corvettes you might have a shot against the older LS1 cars, but anything with an LS2 or LS3 is gonna be tough.
walter
1,054
Houston TX
Nov 27, 2009
  • Nov 27, 2009
Suspension kit, watts link, brakes, wheels and tires.
With some shopping and your own wrenching that can be done for that much.
That's what I'd do for 4K bucks.
E
echo4joe
Beaufort, SC
Nov 27, 2009
  • Nov 27, 2009
For some reason, I'm hell bent on a turbo or supercharger. I want to be able to walk away from other cars should the need arise. If I need to wait and save... Thats what I'll do. And I'm in S. Carolina, which means I could run strait pipes all the way back if i wanted, so exhaust isnt a problem. I want more air and more fule!!!
ct07gt
377
#10
  • Nov 27, 2009
  • #10
There wouldn't be much gain in going to straight pipes, you would gain a little with getting rid of the cats, but you would be so loud that you would get tired of it. These cars do not sound good with off road mid pipes and no mufflers.
You could probably get a non IC centrifugal for under 4k but you would probably not have enough to get it installed. Either save some more for a blower or get a tune and gears. There are a lot of options out there, shop a lot before making a choice.
Five Oh Brian
552
Pacific Northwest
Nov 27, 2009
#11
  • Nov 27, 2009
  • #11
I have an '07 GT automatic coupe. Paid just $3700 for a brand new Vortech V2 S-trim supercharger (non-intercooled). Rest of the engine is 100% bone stock and it makes about 455 flywheel hp. Runs low 12's @ 113+ in the 1/4 mile with drag radials and 100% factory suspension.
If you'll have $4K to spend, the Vortech V2 or V3, or the Paxton Novi 1100 would be great choices that are very upgradable later as budget allows.
GreyDiesel
167
Denver, CO
Nov 27, 2009
#12
  • Nov 27, 2009
  • #12
thanks Five Oh. I was going to say the same exact thing. You can get a centrifugal supercharger for 4k, and that would be what you want.
Centris dont make the low end power like a twin screw, but, that makes it easier to hook up, and then they give great power at the top end. So, you'll be hooking up better then blowing by anyone you missed at the other end of the track.
You'll probably also want some wider wheels and tires. That is going to go over budget, but what doesn't?
chad9350
248
Lake Charles, LA
Nov 27, 2009
#13
  • Nov 27, 2009
  • #13
First, Im not being an ass, just letting you know what you are REALLY in for...
Ready, set, GO!
Well then, lets get started with the little things
FI kit 6K at least
cooling upgrade
I/C or at least resovoirs... 1K at least
fuel upgrade, pump(s), injectors, rails 1K at least
tuning 1K at least
gauges 1K at least
clutch upgrade 1K
transmission upgrade 2K at least
rear end upgrade 1K at least
driveshaft 500ish
Suspension 1K at least
Tires... maybe even a set for the track... cheap ones 1K
Be sure to keep in mind this is doing ALL the work yourself, and it all working the first time, nothing ever breaking.
At the very least, and with everything going right the first time, yourself... perfect world conditions.
12K at least
THEN, when you get all that worked out... might wanna think about
heads 2K
cams 1K
shortblock 4K
done yourself...
20K
Ready, set, go!
E
echo4joe
Beaufort, SC
Nov 28, 2009
#14
  • Nov 28, 2009
  • #14
If I had 20k... I would have put it down on a super snake. Or bought my wife a new set of...
lightblade
366
Nov 28, 2009
#15
  • Nov 28, 2009
  • #15
Vortech V3 non intercooled 6-8 psi and your good to go shop around and u can find a kit for well under 4k and get it installed and tuned and you are good to go.
T
TheVat
98
So California
Dec 1, 2009
#16
  • Dec 1, 2009
  • #16
Do you want to pee in the C6 cheerios from a dig or a roll? 4K centri S/C isn't going to do it. Not to be a jerk but the C6 is about 200lbs lighter with around 370rwhp. I'd say 450rwhp should put a hurting on them. But at that power, the internals and hardware may need some updating as chad 9350 mentioned.
blbrchnk
268
Bridgeport, WV
Dec 2, 2009
#17
  • Dec 2, 2009
  • #17
I thought the general consensus was that most of our cars could handle around 430-450rwhp without altering much else? Any power over that may be a different story, but I know that there are a lot of people running those numbers on otherwise stock cars. Seems that is the power level that a lot of of power adders on the market take these cars.
walter
1,054
Houston TX
Dec 2, 2009
#18
  • Dec 2, 2009
  • #18
Personally I think the brakes and suspension (including wheel/tires) are 100% inadequate at stock levels for any type of performance driving. I'd address those issues and learn the car well before dumping power and money into making the car an unstoppable fiasco but this of course is just my 2c.
ZeroLink
26
TX
Dec 2, 2009
#19
  • Dec 2, 2009
  • #19
+1 (I think I am doing that a lot tonight) Walter is right! Get to know the car first. Then when you upgrade something, the difference will be noticeable and worth it. Does that make 4¢?
Five Oh Brian
552
Pacific Northwest
Dec 3, 2009
#20
  • Dec 3, 2009
  • #20
I've raced several bone stock C6 Vettes at our local dragstrip. Pretty much dead even race, with me launching harder, beating them to the 1/8 mile and them nearly catching me at the 1/4 mile traps.
1 of 2 Next Last
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
Fox body - godzilla, coyote, or 408w stroker - Best route for budget build?
  • jaygee15
  • Jan 27, 2025
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2025
2000xp8
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
