Prince95GT Founding Member Sep 29, 2001 335 0 0 Canada Jul 23, 2006 #1 Jul 23, 2006 #1 I think its the 157 which is mass air related I believe, it seems to only happen when I pin it for a bit and will be on when I lay off then soon after goes away.. but it doesn't always happen
MysteryMachine Active Member Jun 21, 2003 1,835 2 39 Parkesburg, PA Jul 23, 2006 #2 Jul 23, 2006 #2 Have you ran the codes? By your post it sounds like you haven't just wanna make sure. You will also get one once in a while for the egr valve
Prince95GT Founding Member Sep 29, 2001 335 0 0 Canada Jul 23, 2006 #3 Jul 23, 2006 #3 well the last 4 times i checked it was 157 and it happened for the same reasons, so I figure this will be the same code
MysteryMachine Active Member Jun 21, 2003 1,835 2 39 Parkesburg, PA Jul 23, 2006 #4 Jul 23, 2006 #4 oh ok. Have you cleaned your maf? Checked the wires going to it? Not too often they go bad possible though I guess
Prince95GT Founding Member Sep 29, 2001 335 0 0 Canada Jul 23, 2006 #5 Jul 23, 2006 #5 yeah I have tried cleaning it, all seems well til but it comes back
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Jul 23, 2006 #6 Jul 23, 2006 #6 Are you clearing the KAM after you retrieve codes each time? Just making sure. If you have a meter, you can do some voltage testing at the MAF. Good luck.
MysteryMachine Active Member Jun 21, 2003 1,835 2 39 Parkesburg, PA Jul 23, 2006 #7 Jul 23, 2006 #7 did it come on before cleaning it? JT probably knows more about this stuff then I do. I'm just pulling stuff out my butt that could be possible issues
