One man job?
  • Thread starter Thread starter GREYFOX4INCH
  • Start date Start date Mar 29, 2006
G
GREYFOX4INCH
190
western MA
Mar 29, 2006
  • Mar 29, 2006
can anyone suggest a few tricks or tips on how to install a fatory H-pipe (the heavy one) with no helper. usally i would have a friend lay under the car and hold it in place so i could put on the header nuts. then each person lays on each side holding up your side while putting in the exhuast hardware.
(THE L SHAPED HANGERS HAVE BEEN CUT OFF THE H-PIPE)
if anyone has a good method that they use I would like to hear it.
also i am doing it with a jack and jack-stands. and have done it about 4 times but never alone. i know im not strong enough to hold up the whole pipe/line up the holes/and put on the nuts. so.....
could i put a rope over the tranny and tie it up there while i get the nuts on?
later
Euphoric306
905
  • Mar 30, 2006
damn, that doesn't sound like a bad idea. i always just slip the hangers into the exhaust hanger and it's easy, but you're unfortunate in your situation. it's not that hard be on your back and lift the thing up by yourself, but like you said doing that screwing on the header nuts at the same time would be a bitch
G
GREYFOX4INCH
190
western MA
Mar 30, 2006
  • Mar 30, 2006
indeed it is, my offroad pipes have hangers but this damn catted oem pipe gives me trouble.
when my friends call me on the weekends and i say i am working on my car, they respond with
"oh ill give you a call later to see what your doing"
i dont even ask for help anymore. im not willing to beg for that type of friendship. i offer to help my friends ya know. owell
281pony
2,681
Oly, WA
Mar 30, 2006
  • Mar 30, 2006
try strapping it up, using a jack to hold it in place or even in combination with the jack stands.
hell, i did my mid-pipe before on my back, using my knee's to hold it up. then reached my arms up and started the header flanges.
Vinnietbird
584
  • Mar 30, 2006
I held mine up with my legs until I got the driver's side started (the easiest side on my T-Bird),then,moved over and got the other 2 nuts started.After that,it was just a matter of tightening the nuts.
Black1987Stang
1,422
Jersey Shore
Mar 30, 2006
  • Mar 30, 2006
i have no hangers also on my o.r X and have done it many times with just the front on wheel ramps...i just lat under the midpipe it with the bottom 2 legs on the top of my feet and push the top it up, throw it a nut or two, do the same all around then tighten them up...and i think i also used a jack under the front part a few times too...
G
GREYFOX4INCH
190
western MA
Mar 31, 2006
  • Mar 31, 2006
yeh thats kinda was i was thinking i would try, baybe ill try to prop/tie part of it up and hold with my legs too.
the stock pipe is just a little heavy. one of my buddies who i dont talk to often actually just offered to give me a hand with it on Sat so maybe ill wait and see if that goes through. thanks
281pony
2,681
Oly, WA
Mar 31, 2006
  • Mar 31, 2006
have fun, exhaust work is one of the things i HATE doing.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
