Fox One Piece Headlights
  • Thread starter Thread starter keithwiggi02
  • Start date Start date Mar 12, 2015
  • 3
  • 4
First Prev 3 of 4 Next Last
hoopty5.0
mechanicus terribilis
7,825
6,977
214
SW Houston
Mar 14, 2015
#41
  • Mar 14, 2015
  • #41
BUT DAAAAAAD! He started it!
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 14, 2015
#42
  • Mar 14, 2015
  • #42
I had to go back and see if one of us removed some offensive comments or something? I don't see what set this guy off?
Has everyone gone Emo or something?
Admin Dude
Jan 4, 1985
43,500
21,673
234
Box behind Walmart
Mar 14, 2015
#43
  • Mar 14, 2015
  • #43
We appear to be victim for a new era of cyber attack. It's called, "Hit and Run Butthurt". I think they start butthurt and join the interwbz. Once on interwbz, they join the secret society of TehFB. This society raises them to explore their inner ButthurtEDness and to share the Butthurt with those that are less Butthurt. They arrive conscious of only TehFB cyber mentality. It is their gospel. The know that once inside our very halls that their ButthurtEDness will flow. Instigation is not necessary. For those of the faith know what we mere forum mortals do not.... ButthurtEDness just is.
Onefine88
Previously 89SSC18
1,422
796
154
Mar 14, 2015
#44
  • Mar 14, 2015
  • #44
So!
I guess we are all (except OP) in agreement that the one piece headlights look like S--t then.
Reactions: 02 281 GT
Admin Dude
Jan 4, 1985
43,500
21,673
234
Box behind Walmart
Mar 14, 2015
#45
  • Mar 14, 2015
  • #45
Onefine88 said:
So!
ButthurtEDness
Onefine88
Previously 89SSC18
1,422
796
154
Mar 14, 2015
#46
  • Mar 14, 2015
  • #46
Noobz347 said:
ButthurtEDness
LOL
Not all newby's have what it takes to make it past the initiation process around these parts.
Reactions: f8tlfiveo and Noobz347
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Mar 14, 2015
#47
  • Mar 14, 2015
  • #47
I dunno.. Maybe he was hoping for the first couple of replies to be something of content besides that they're horsesht. I just googled the one piece headlight, yeah they're ugly. Make this link a sticky in the tech section since everyone likes em so much.
Fox Body Mustang One Piece Headlight: Install Video
Admin Dude
Jan 4, 1985
43,500
21,673
234
Box behind Walmart
Mar 14, 2015
#48
  • Mar 14, 2015
  • #48
Oh, you mean like this one?
FoxMustangLvr said:
You shouldn't care about other peoples opinions on how something looks like 1pc vs 3pc headlights, it's your car. If you need help with install or what kind of lamps are best then that would be something I'm sure we could chime in on.
You should read the reviews on LateModel in regards to the 1pc, I believe some of those lights are not sealed very well and sometimes don't match the lines of the hood and fender as well as 3 pc lights.
or this one?
jrichker said:
My experience with aftermarket headlight lenses...
Aftermarket headlight lens kit - It took about 7 days to get the lenses, 20 minutes per side to install all 3 lenses and forever to try to align them.
I drove around for several days with the driver’s side headlight scanning the upper branches of trees for squirrels, owls and UFO’s. The headlight lens had extra slack between the retaining clip and the screw head which allowed the lens to shift around. I fixed that with some small washers between the screw heads and the bottom of the mounting hole. I would recommend that you find 2 extra adjustment screws per side - they are the ones with the hex ends on the end of the screw where it sticks through the mounting plate. That may help the alignment problems, as the stock setup only allows adjustment with 2 screws, and is hard to adjust in and down at the same time.
If you bought Genuine Ford headlights, the adjustment will be easy. If you bought reproduction headlights, they will be very difficult to align properly. I bought reproduction units the first time, and my headlights could not be aligned: they would shine up in the trees and across the road. I even had all 3 screws set up as adjustment screws.
The adjustment screws are upper inside and lower outside screws. If the headlights were re-assembled properly, they will have a 5/32" hex on the screw. You can use a 1/4" ratchet with a 5/32" socket. The upper screws can be reached with the hood up, while the lower screws may require you to lie on the ground in front of the car and reach them from the bottom.
To align the headlights, find a level spot with a wall 25-30 feet away. Disconnect the driver light and align up the passenger light so that the light pattern is slightly below of the actual centerline of the headlight. This is to illuminate the right hand side of the road. Reconnect the driver light and disconnect the passenger light. The driver light should be aimed so that the light pattern on the wall is inward about 6" and slightly below the centerline of the headlight. This keeps you from blinding the oncoming cars. Disconnecting and reconnecting the headlights helps to show which headlight is shining in what direction. Reproduction headlights may shine in several directions at the same time, making it very difficult to align them if both lights are on at the same time
One Stangnetter recommends putting a fender cover over the headlight that isn't being aligned. I like his idea, it's simpler than disconnecting the lamps.
or do you mean the ones where everyone gives 'mad props yo' just for the hell of it?
elarm1
1,428
652
154
N.Va
Mar 14, 2015
#49
  • Mar 14, 2015
  • #49
Virtual said:
Just saying that I hope you don't leave. Don't let the attitudes and opinions of a few others stop you from soliciting opinions or advise. FWIW I don't think any response was directed at you personally.
Seriously..... lighten up bud and
billbosc
122
9
28
Mar 14, 2015
#50
  • Mar 14, 2015
  • #50
I like the one piece personally. Newb or not I think it's a cleaner look. Just my opinion though. Guess I'm a piece of . But I already knew that. I hate you guys. I'm taking my ball and going home!! Lol
Sent from my iPhone using Tapatalk
Reactions: Noobz347
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
Mar 14, 2015
#51
  • Mar 14, 2015
  • #51
Darn, late to the party again!
I do not mind how the lights look. It is your car. Some of the LED tail lights are cool and some are ugly too, but it is not my car. What I do mind is how they function. That middle piece needs to be adjusted separately or it shines in MY face, or the UFO's, and that is bad. Or you have problems with body lines.
I have noticed since Taco Bell de-rails left, many, many of us need to be less grumpy. How about a round of Prozac for everyone? If not, how about a good spring to lighten the mood?
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Mar 14, 2015
#52
  • Mar 14, 2015
  • #52
billbosc said:
I like the one piece personally. Newb or not I think it's a cleaner look. Just my opinion though. Guess I'm a piece of ****. But I already knew that. I hate you guys. I'm taking my ball and going home!! Lol
Maybe it's an age thing? (Not a knock at ya). Could it be that the younger crowed diggs em and the older ones dog em?
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
Mar 14, 2015
#53
  • Mar 14, 2015
  • #53
:worthlesaId like em but they accentuate the poor panel and hood alignment too much and no one can fix it, and they kinda look like my honda headlights.... proper product on proper car,
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 14, 2015
#54
  • Mar 14, 2015
  • #54
You're on the pipe again, aren't you?
Re-read those first few replies before he "threw the wobbler", then took his ball and went home. They were both opinionated (without being crass) and informative.....just like one would assume a normal person would want? They were as good a reply as you would find on the internet. If he wanted nothing but praise and to be lied to, to make him feel better, he should have joined a cheer leading squad, or a support group....not signed onto the internet as asked, "any thoughts"?
I swear....I should talk Mike into implementing a personality disorder test prior to joining, just so we can weed out the potential rubber room posters.
90lxwhite said:
Maybe it's an age thing? (Not a knock at ya). Could it be that the younger haven't developed a sense of good taste yet and the older ones are are past the foolishness?
Fixed that up for ya ^
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Mar 14, 2015
#55
  • Mar 14, 2015
  • #55
Ha yeah tuche. Nah on the pipe, just at work. I re-read.
Reactions: Gearbanger 101
billbosc
122
9
28
Mar 14, 2015
#56
  • Mar 14, 2015
  • #56
Some
People are just hard headed and
Close minded. Simple as that really. To each there own. I
Still only really see a couple things that are actual evidence of the one piece not being as good of an idea as the original three piece. Accentuation of the lines I totally get. I see also some say they are not aligning well and pointig in the wrong direction. As for taste. That's just what it comes down to. Some like the original look and I personally see nothing bad about that. I personally just like the one piece style look myself. I have not ran into any issue with aligning my lights correctly. So to me that just doesn't seem factual. The lines I can tell it Definately makes it show a little more. But not ebogh that I would go to the extreme to say someone is an idiot or has bad taste or will never learn. That is all
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Mar 14, 2015
#57
  • Mar 14, 2015
  • #57
Did the "smoked" headlight fade die out? They kinda looked ok but have yall ever ridden in a car that had em at nite? They were some dim bastards.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 14, 2015
#58
  • Mar 14, 2015
  • #58
Holy crap. 56 posts on 1 piece headlights.. What's next- what color neon lights shoulld I install in my Fox body?
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Mar 15, 2015
#59
  • Mar 15, 2015
  • #59
It'll probably be in the wrong section whatever it is
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
Mar 15, 2015
#60
  • Mar 15, 2015
  • #60
Serious theyre available? Cool
  • 3
  • 4
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
F
Black Headlight Area
  • frwgt350net
  • May 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Willybill32
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 6:53 PM
Don7Up
D
