One tire Spinning!!
  • Thread starter Thread starter almostbritish
  • Start date Start date Oct 10, 2005
almostbritish
  • Oct 10, 2005
What is the cheapest way to lock up my rear diff? I have heard of welding the "??spider gears??"" together?? Any tips I have a 1989 lx with a 8.8 open diff and 2.73.1
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Oct 10, 2005
  • Oct 10, 2005
no dont weld ur spider gears thats the worst thing to do buy a locker befor u even think of tht.
Dean85GT
502
Thorold, Ontario, Canada
Oct 10, 2005
  • Oct 10, 2005
or you can just get a trac-lock rebuild kit.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 10, 2005
  • Oct 10, 2005
Traction-loc rebuild kits go for about $50 or so. Rebuild it, it will be fine.
almostbritish
  • Oct 10, 2005
Trac loc
Did my car have trac loc to begin with??
How do I find out?
HISSIN50
34
129
Oct 10, 2005
  • Oct 10, 2005
To me, open diff connotates a rear end with no limited slip provision. Yours is worn out, but not open.
A search will reveal tips people like to do like using an extra plate, etc.
Good luck.
90mustangGT
2,773
17
89
Dallas, GA
Oct 10, 2005
  • Oct 10, 2005
Open it up, it will have clutches and plates behind the spider gears and a S spring between them through the pinion shaft.
almostbritish
  • Oct 10, 2005
are most 1989 lx mustangs locked in the rear??
slow93
406
  • Oct 10, 2005
hmmm,all of the 89s i know of have traclok,yours if prolly just wore out like mine is.
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Oct 10, 2005
#10
  • Oct 10, 2005
  • #10
How do I find out?
You can post your driver's door tag's axle code here, or crawl underneath and see if your ratio number (i.e 3.08:1) is listed as 3L08 for locking or 308 for open.
almostbritish
#11
  • Oct 10, 2005
  • #11
Door Tag
This is everything that I got off of my door tag:
1FABP41E2KF266406
618 xxx E9 C Z 2PPBB
F0168
R0097
57
Realmongo
2,466
86
99
Western Mass
Oct 10, 2005
#12
  • Oct 10, 2005
  • #12
1FABP41E2KF266406
F0168
R0097
57
A rear axle code of Z indicates a 3.08:1 Traction Lok rear.
almostbritish
#13
  • Oct 10, 2005
  • #13
Spline Count??
What would be my spline count?
28,31,33
Realmongo
2,466
86
99
Western Mass
Oct 10, 2005
#14
  • Oct 10, 2005
  • #14
28 if it is stock.
almostbritish
#15
  • Oct 10, 2005
  • #15
rebuilding
Is the rebuild a pretty straight forward job??
I know that installing gears is best to leave to the pros.
Realmongo
2,466
86
99
Western Mass
Oct 10, 2005
#16
  • Oct 10, 2005
  • #16
It is not bad because you don't have to touch the pinion gear, just put it back together with the spacers that come out. You can add extra clutches to make it lock up tighter. Have a look at the October Mustang Monthly to give you an idea as to what is involeved in removing and installing the Traction Lok
almostbritish
#17
  • Oct 10, 2005
  • #17
thanks for all of your help realmongo!!
Realmongo
2,466
86
99
Western Mass
Oct 10, 2005
#18
  • Oct 10, 2005
  • #18
Just glad if I helped.
Drivetrain 8.8 trac lok spider gears..
  • rednotch
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 28, 2025
rednotch
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
Differential noise over bumps
  • sharkrat
  • Apr 10, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 18, 2026
TPony
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Hi from Western Washington
  • Bannister
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 31, 2026
keel
