One wheel peel
1slow95
1,797
ohio
:( Looks like it's time to beef up the rear end! I want to go with a new diff and 31 spline axles, what brand should I look for? It definitely needs to be street friendly, and Im looking to spend no more than $500-700 on everything.
I know this question has probably been asked several times allready, but Im too lazy to search.:p
I have always heard great things about the Eaton rear ends but they are pretty expensive. I will most likely go with Eaton or a Ford Truck 31spline trac loc when the time comes. Sorry dont know much as far as axles go though.
right after my 408 swap, I went ahead and put in an eaton posi and superior 31 spline axles. The eaton, as opposed to an Auburn differential, is rebuildable, and so far, it holds very well and has great street manners.
I spent about $700 on parts and a rebuild kit, plus about another $250 to get it professionally installed. I thought about doing it myself, but getting the rearend installed right is important, so I didn't want to botch it up.
sorry to hi jack- but do the 99+gt's Differential bolt right up? I know my friend had one on his car but he never really told me if it just bolted right up...
With a manual car, you'll want to go 31-spline...
With my car, I bought a drop in replacement Powertrax No-Slip locker. Very street friendly, ABSOLUTELY no one-wheel peel after fighting with the stock traction-lok for months and months.
Thanks for the suggestions guys. Where can I find more info about the Powertrax locker?
I've also thought about going with the f-series t-lok...Do they work much better than the stock diff? I only have about 20k on my rebuilt stocker and it's slipping again.
Search these forums...you should find alot of info from the posts I had concerning the Powertrax.
Basically, it's a drop in piece that replaces the "guts" of your traction-lok carrier (or open diff carrier) and turns it into a locker..
It works great, but with a stick shift and a lot of power I'd worry about using the stock drop in. Now, a 31-spine setup and a Powertrax No-Slip would be AWESOME...
