One Wheel spinning??
Andre G
107
I took off hard from a light tonite and my friends behind me said my passenger side wheel was peeling out but the drivers side wasnt doing much... what could of gone out on my rear end?? the car is an 02 GT with 86k miles thanks...
maybe it never came with posi...
Lift it up and rotate the tires, if one spins one way and the other another you have an open dif... As far as I know there is nothing in there to break to cause just that problem...
It's hard to diagnose rear end problems with information like that. A better way to test would be to do a full on burnout and see if both wheels go.
I have the same problem in my 2002 GT.
1st off i beleive -ALL- GTs came with "posi" or Fords Traction Lock, and i think if yours does not work (like mine) the problem is in the differential or clutch pack.
Before you do anything:
I hear, there is this additive that you can add to your differential to help loosen up the limitted slip and get your "posi" back. I beleive Ford might have this addative, i dont remember the name, but try asking them for a "rear end differential addative" to help loosen up your locked limited slip.
my 97 has no type of traction control....btw, when i was at the track this weekend i did a hard burnout...trying to get a really nice launch, so i burned all the way through all of 2nd and it looked like (from inside the car) that i just lit the tires up. i felt really good about it, went to launch and hooked extremely hard on the passenger side but not at all on the drivers. so i basically just jumped to the right and had to let off. i think one side of the car was in some water that was drug up by the prostock car before me on one side...i guess...i haven't had any problems withit this week so i'm guessing that was the problem.
It could be worn? And how good are our stock limited slips? It is easy to over power limited slips or if one has close to zero traction all power can still go to the one tire. Also limited slips only do about a 70/30 power split. Thats why hard core drag racers, and us with 4x4's run lockers. Full 50/50 split whenever throttle is applied. :nice:
I am assuming you clutch packs are shot. input torque is what drives a posi. If you are frying one tire and not the other obvioulsy you are applying the torque.
Another thing that can happen is during a cars life someone can change the rear diff fluid and not use the right oil or add any friction modifier. if you are haning issues of proablems with dissengament or noisy diff you can add more modifier but if the clutches are done you most likely need a rebuild.
86k seems like short life. my iroc has 150k and I can still lay 2 black marks at will.
Don't replace a damn thing in there until you know that something is broken.
A single 1 wheel launch doesn't necessarily mean something's broken. Like Tom said, they happen.
Ever had a rougher than normal ride on a familiar road? You wouldn't go replacing the shocks right away would you? Heck no, you isolate the problem first, then replace.
i would say its time for a rearend rebuild. if your car continues to do the same thing. sometimes my car peels 1 wheel sometimes both. i haven't rebuilt it yet because it hasn't let me down at the track yet with slicks. peels em both. so wait for a while and if it continues all the time then rebuild.
Andre G said:
how much is a rebuild kit and can I get it done when i get my gears put in???
thanks
Traction-lok rebuild:
A brief traction-lok description: The t-lok, IMHO, is a very simple yet effective method of torque transmission. It uses a combination of frictions and steels; the steels spline to the O.D. of the side gears (the I.D. is splined to accept the axles), and the frictions keyed to the differential case (driven by the ring gear) with tangs. An S-spring is used to provide initial clamping load, then is supplemented by the outward forces created and transmitted by the pinion gears.
If you plan to rebuild the traction-lok, it is advisable that you do it now, for a couple of reasons: 1. Going to a numerically higher gear ratio, the pinion diameter goes down, and the ring gear thickness goes up. What does this really mean? The S-spring "gap" between the side gears is partially blocked (straight line of sight) by the thicker ring gear (you can still get the spring in, it's just a bit tougher). 2. Without the ring gear, you can support the differential case by the flats (across the clutch cavity) on a block of wood, while driving the S-spring in place. Also, there are two approaches to component order: the factory method, and the alternating method. From the factory, t-lok's are packed in this order: shim, friction, steel, steel, friction, steel, steel, friction, side gear. The alternating pack is as described: shim, friction, steel, friction, steel, friction, steel, friction, side gear. There is some debate on the durability of the alternating method, as you have reduced the number of splined components (thereby increasing shear and contact stresses), while increasing the ability to transmit torque. My contention? I've never seen a rearend go out due to t-lok spline failure; it's usually axle related (OK, at some point the axles become stronger than the steel splines; at which point, I don't know! Maybe somebody ought to "run some numbers"...). Both methods work: satisfy your particular needs and plan accordingly (I prefer and suggest the alternating method, FWIW.). The F5AZ-4947-BA kit will allow you to accomplish the "factory" set-up; for the alternating, you can buy a pack of frictions (see number below), or reuse two (one for each side) of your best existing frictions.
The rebuild: Soak the frictions in gear oil for a minimum of fifteen (15) minutes (while you clean the diff case, gears, and shims) prior to assembly in order to avoid dry working and possible component damage. Be forewarned: the clutches will still pop when first driven (I about had a conniption when I first rolled mine out of the garage after gears and t-lok! The thing popped about a dozen times in turns before settling out. I soaked mine about twenty (20) minutes, but the last set I worked on was soaked for about two hours. Result: only one or two mild pops, even with alternating frictions and a new F-150 S-spring!). With the differential case on one bearing, install the .045" thick shim in the bottom cavity. Apply a few drops of gear oil to the other .045" shim and place in the upper cavity (the oil will hold it in place, as long as the drops are towards the case...). Stack the frictions, steels, and side gear (engaging steels) in the lower cavity per your packing choice, then stack the upper units on the side gear, and install as a unit (make sure tangs locate in case). Install one of the pinion gears in place, and, while holding inward with one thumb, install the opposite side pinion gear 180 degrees apart (I prep the pinion gears first by putting a couple drops of gear oil between the gear and it's steel bearing "shell"). Pick up the whole assembly, and install on the end of an upright axle. Rotate the diff case while holding the pinions inward as hard as possible; if you're lucky, the "assembly" will roll right into place. If the shims are too thick, the pinion gears will not clear the case (acting like a built in gauge...). Change one shim to the next thinnest, and try again. If it fails to go together, change the other shim to the next thinnest: repeat until the gears rotate into position. It's fine to have one shim .005" thicker than the other; just don't end up with a .010" disparity. If the pinion gears line up, and the shaft will go through, you have it correct (It took me about three tries the first time.).
S-spring installation: This is actually the most trying part of the whole procedure! The S-spring, by design, has to be compressed to allow installation. The Ford (Helm) manual directs you to tap it into place with a rubber hammer; maybe one that weighed about 1000 pounds and was frozen rock hard! More people have had difficulty with this one seemingly simple task, and I'm no exception. I fought my first one for about an hour, then finally got it by compressing it in a vise, holding it compressed with a couple of pairs of needle-nose Vise-grips, and driving it into place. Shortly thereafter, Larry Turvy from the Corral offered a great tip: use two, 2" capacity worm-type hose clamps. Larry's original suggestion was to use the clamps to compress the spring, but I still use the vise, then install the clamps, leaving a bit of the end exposed to get the thing started. Place the compressed spring into position, and start driving it into place with a hammer. With all luck, the spring will start in a few blows. Continue driving the spring in, until you stop on one of the "worm" portions of the clamp. Cut this clamp out with aviation or tin snips (Dremel or hacksaw may work), and continue driving, removing the other clamp when required. (Note: I found a 6-8" long piece of 1" x 1-1/2" rectangular tube, used as a "punch", to be very helpful in "persuading" the S-spring into position, especially when using the F-150 unit!). Be careful not to drive the spring all the way through and out the back; sight down the pinhole and roughly center the spring. Set the unit aside for the time being.
Congratulations! You've just completed the Traction-lok rebuild!
heres a rebuild kit click on link.
http://cgi.ebay.com/ebaymotors/Ford...33731QQitemZ8022836455QQrdZ1QQsspagenameZWDVW
I know what did it.....:( my friend works at a mobil one and he changed my rear diff fluid a few months back and used whatever they have up there but I didnt think anything about it :/......
