One-wire alternator help
  • Thread starter Thread starter superhuaman
  • Start date Start date Oct 28, 2006
superhuaman
907
Harrisburg, PA
Oct 28, 2006
  • Oct 28, 2006
I have a Powermaster 140A alternator on my '90 306 and it started acting up yesterday. I don't know if it was the cold, or what. I started the car and the volt gauge read battery voltage. (it's done this before, it's normal cuz of my idle speed and the turn-on speed of the alternator) i then revved the engine to get it to start charging, and it pegs the volt gauge! i verified with a DVOM and it was slowly but surely creeping up past 18 volts. what is going on with this... i checked all the 4 gauge wires and theyre tight...
04sleeper
2,674
14
89
Dallas, TX
Oct 28, 2006
  • Oct 28, 2006
You alternator should have an internal voltage regulator. It sounds like it has gone bad. I would not run the car like that as it could overcharge and burn up some things.
I had one do this in my 82 GT and it blew the tops off the battery and acid got all over the engine. It ate through my radiator hoss, spark plug wires, paint.....basically everything it touched.
marine_2003
427
Lake County, FL
Oct 28, 2006
  • Oct 28, 2006
I had a one wire alt on my 85, and indeed, they should have an internal regulator. I would take it down and have it tested. Also do you still have the regulator that came with the car?? That might be a problem if it is still hooked up, I had something similar happen when i switched over to the one wire and it was because of the stock voltage regulator.
superhuaman
907
Harrisburg, PA
Oct 28, 2006
  • Oct 28, 2006
marine_2003: the stock voltage regulator is on the back of the stock alternator, so that's not causing a problem here.
i know its got an internal regulator. it HAS done this once before...i THINK i fixed it by tightening a connection somewhere, but i cant remember. there arent any loose wires right now that i can find.
btw, this alternator is based on the GM Delco 10SI series alternator. do you think if i got a "one wire conversion kit" for gm alternators that that would come with the parts i needed? or should i just call powermaster?
G
2000 GT- Alternator not charging
  • grugug
  • Nov 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 12, 2026
squeak93
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
