Flowmaster makes the one-chamber race mufflers in regular style (one internal delta baffle) AND in the Delta Flow (three delta baffles) series.... except the one-chamber delta is called the "Delta Force" series. The Delta series, just like all of the Delta series mufflers, will have a 9 in front of the part number, the regular one will not. Example: FLO-42543 , FLO-942543. (both examples are offset in/out two chamber 40 series, by the way)
I've had both styles of the one chambers and the regular one is by far the loudest. They are as close to open pipes as you can get. I like loud and obnoxious too, but I really did get tired of being THAT loud ALL the time. The Delta Force one-chambers are loud too, but not quite as loud as the regular ones. They are as bassy and rumbly as the regular ones, but without as much high pitch and mid-range "groul" (pretty much like ALL Delta series mufflers).
I MUST note however, that both one-chamber styles sound like total CRAP with tailpipes! Tailpipes usually won't change the sound of a muffler so drastically like these do, but the sound totally changes when taillpipes are added. They get that "flappy" sound like an old truck with glasspacks. With dumps they don't. Please learn from my mistakes and my wasted money. If you want that sound, go with some glasspacks and save a bunch of money.... glasspacks are what, like $15? (I'm kidding....don't get glasspacks)
Another thing to consider is that the one-chambers are short mufflers and are center inlet/outlet, so to use them on a mustang, your flowtubes will have to be cut, altered, welded, etc, to make them fit. And making tailpipes fit with them is a total nightmare. Your exhaust will looked hacked, rigged, and ugly.... which might not bother some, but it bothered me.
Summit does not carry the original one-chambers, only the Delta-Force ones. Some other race catalogs still carry them, so they are still available.
Hope this helps.
