Opening rear hatch without key
go to the outside of the car.. Under the lock cylinder on the hatch there is a little plate scrwed on. remove the skrew and plate then pop the lock cylinder out. Stick a long flat skrewdriver in there and bang the hatcjh is open. I 've had 3 mustangs and there wasnt a hatch release cable in any of them there was only a fuel door opener.
Thanks! I found it but it's not a screw...it's a really small nut that doesn't seem to fit any of my wrenches unless it's metric. I'll get it off one way or the other.
he lost the key and you guys are giving him ifo about oiling this and that? If you follow the procedure i gave you you can replace the lock cylinder so you can acess your hatch via key.
RsStanG1987 said:
Your on the outside of the car right?
Yeah, right under the lock on the outside. I know exactly what your're talkin about. Mine is not a screw...that's all. It's between a 5/32 and 5/16 and none of them fit so it must be metric...
