opinions for new engine block
just4bob50
504
Pa.
I have found out why my coolant system is constantly being presurized and I why my head gaskets blew out at the water jackets twice now. I have a crack in the cylinder wall of the #4 cylinder. So now my options are buy a rebuilt production short block with forged pistons and run only about 6lbs of boost, but buy better heads to go with it. Option 2, buy a strong bottom end with an aftermarket 302 block, and run my current combo till I can afford better heads later. I have about 2500-3500 to spend. So what do you guys think.
your cooling system should be pressurized and not leaking or youll have hot pockets:p
I guess I should have said ( over presurizing the coolant system ) you shouldnt be spitting coolant out of the overflow tank like I was as well as the other symtems I described. That being said I still have a cracked block.
no its not over pressurized either its blowing fumes through the crack in your block into the water which is making it bubble out sorry bout that go with option number 1 so you dont have to wait on more parts youll have money to spare in case smthg else goes wrong
