Opinions on radiator repair??
jaymac
995
Northern Mass
For a pinhole (that's obviosly big enough to leak through, do you guys recommend full replacement, or that radiator repai in a bottle stuff, or what?
It happened while trying to hammer off the old water pump, the ball-peen end tapped the fins, barely enough to bend the fins, but enough to create a hole, apparently. It's enough to create drips.
What's my best bet?
Thanks -
J
Replace the radiator or have it professionally rapaired. I would stay away from that crap in a bottle because that runs throught the entire cooling system and if it plugs a leak what else is it gonna plug, that scares me.
Good old vice grips will fix her like new...ok jk but i have fixed 2 pretty big size holes in a tube with vice grips:rolleyes: and one I fixed in a parking lot, a guy came over and was like theres no way thats gonna work haha, its held for over 2 years on his daily driver and the other i fixed my moms honda radiator but that was only a temp. fix the next week i changed the radiator. Im not suggesting to do it, just sharing my experience :nice:
I have sucessfully fixed leaky radiator tubes with a propane torch & solder. I will have to admit it wasn't pretty...
I have used blue RTV on a radiator before and it stopped the leak. Depending on where exactly it's at, maybe you could use some JB weld? I wouldn't use the stop-leak stuff for the reasons mentioned above: it clogs up your whole cooling system, not just your radiator.
You could probably get a 2-core radiator for $100-150.
