Hello again, I posted a few days ago about an 85 GT AOD/CFI I'm considering buying for my son. Thank you for the comments about the water pump. We replaced the pump yesterday and we're good there now. I have a few more issues that I discovered now that we can drive it a bit. After reviewing the issues, is it worth $1,900? This appears to be a pretty good deal, even if I have to fix the issues below.
1. There is water dripping under the car just under the driver. Can't locate the drip and the water is cold. It might go away as it might have pooled when we filled the radiator.
2. Heat doesn't work, blower fan and controls seem to work.
3. AC needs to be charged I presume, but it is engaging the clutch.
4. The Check Oil light came on today, but I discovered that it was 1 quart low. Filled it up and the light went out.
5. Oil pressure appears low when warm, but I'm using the factory gauge right now. It rides at about 1/3-1/2 depending on RPM, and almost drops to the low line at idle.
6. Fuel gauge doesn't work. Shows full when full, but quickly drops to empty for the duration.
7. Headlight switch is broken and hangs out of the hole.
8. Brakes are very soft and the pedal almost goes to the floor.
