Opinions
  • Thread starter Thread starter Nibbie
  • Start date Start date Jul 8, 2007
Nibbie
127
  • Jul 8, 2007
Today i was driving and the temp ouside was about 95 degrees. Ran fine for about 2 hours and stoped at a gas station. Started the car and it started up and then just wanted to die. IF i let it idle it would barely idle fine, if i steped on the gas it would die. I checked under the hood and it felt pretty hot but the temp gauge was at normal. I waited for 15 minutes till it cooled down and it started up fine like if no problem was there. The check engine light was not on but that dosnt mean anything. I could still have some codes, When i go to work tomarow i scan it with a scann tool. I noticed my air filter was getting dusty and it was also hot. I dont know if my mass air meter is dirty, could be iac, act sensors. This happend to me last week and i changed the distrubitor modual last week, drove fine till today. I dont think the modual could be bad again. I dont know any suggestions? Thanks.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jul 9, 2007
  • Jul 9, 2007
I always start with a basi tune up, plugs, wires, cap, rotor, fuel filter, pcv, then if I still have a problem I go to my tuner and he fixes it with a dyno tune. Anyways, I have seen fuel pumps cut off when it is really hot, or when the pump it self gets hot. The dist module was a good start but those usually just kill the car period. They are not run sometimes not run sometimes. Good luck...
Nibbie
127
  • Jul 9, 2007
i was thinking about the fuel pump also, i think it has one of those car quest crappers in it that only last like 3 years. anybody make a good performance fuel pump? anybody know the stock flow rate to a hi-po fuel rate pump and what would be a good one to run?? might as well pick a good one since ill replace it anyway.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
9
2012 Boss 302 help
  • 94blackvertgt
  • Aug 21, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 21, 2025
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
