Optima Batteries??
  • Thread starter Thread starter 87ttopstang
  • Start date Start date May 17, 2004
87ttopstang
342
Ontario, Canada
May 17, 2004
  • May 17, 2004
Hey guys, in need of a new battery. Are Optima worth the money? I want the blue top as it would match the car better, but it is a marine battery. Should I go with the red?
hllon4whls
BANNED
2,567
Covington
May 17, 2004
  • May 17, 2004
You should not chose an optima battery by the color of the case. There is no reason you cant paint it any color you want to. They are pretty good bats.
cjones
1,561
Avondale, AZ
May 17, 2004
  • May 17, 2004
i've had a blue top in mine for about 1 1/2 years and it's doing fine.
HO93LX302
715
Naugatuck,CT
May 17, 2004
  • May 17, 2004
Optima bats are deffinitely worth every penny.. Yea don't go choosing the bat from the color of the top.. The red top is perfect for any car, but if you have a bunch of electrical componets (like gauges and a system with amps, speakers and what not) get the yellow top.
Blue Thunder
1,003
55
68
Upstate New York.
May 17, 2004
  • May 17, 2004
I bought a yellow top Optima from Summit back in 99 or 00, and it's still functioning perfectly. (my car has been stored outside during the winters, battery in it) I left my electric fans on one time, and when I came back out, the battery had been drained so it wouldnt start the car. I let it sit about 15 mins, and it recovered enough juice to start the car.
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
May 17, 2004
  • May 17, 2004
that red is tough too, I've had 10 speakers and 5 amps running off that batter for two years, and it's still running precious with no alternator issues. I don't know all the math on that, but i killed two batteries really quick before the Optima
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
May 17, 2004
  • May 17, 2004
The blue top is a good cranking battery.
If your not runnig really high compresion or not alot of electronincs the red is great.
If you want to be safe go yellow.
If you want to be cheap (i'm not saying too) go buy a big marine battery.
87ttopstang
342
Ontario, Canada
May 18, 2004
  • May 18, 2004
I have three guages, a tach, an amp and 9.5:1 compression. I think I'll go blue or yellow.
Qwk88LX
202
21
Sunrise, FL
May 18, 2004
  • May 18, 2004
Optima's are good. They've always lasted a good while for me...definitely worth the $$
87ttopstang
342
Ontario, Canada
May 18, 2004
#10
  • May 18, 2004
  • #10
Do they come in different sizes? I was looking at a spiral type of battery called an orbital. Same type as a optima but different name. They only come in one size and I do not think it will fit. I am thinking it will be too tall. Does anyone know how tall we can go?
Q
quik87
161
florida
May 18, 2004
#11
  • May 18, 2004
  • #11
how much compression you have has nothing at all to do with what battery your running. all red tops are the same size..same as the yellow and blue tops........if i was you....i'd go with the red top. be perfect for your needs.
87ttopstang
342
Ontario, Canada
May 18, 2004
#12
  • May 18, 2004
  • #12
again...does anyone know if they come in different sizes. If not, how tall are the red tops from the bottom to the top of the terminals?
cardudeusa
1,744
Home of the Florida Gators!
May 18, 2004
#13
  • May 18, 2004
  • #13
All the ones I've seen, blue, red, yellow were the same size. I had to customize the hold down mount, but nothing big.
M
Fox Random spike voltage (Need help from scope users)
  • martroy
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
martroy
M
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
