Optimal fuel system?
Djstorm100
109
Going to try and make this clear and possible sorry if there is any confusion.
I was going to run -10an line form the fuel tank (sump) to y-block to two warblo GSL 392 pumps another y block and -10an line to the front of the car.
This is where my question comes in. The fuel line coming from the fuel pump should I...
1) connect it to one fuel rail, then run another -10an line to the other, then from the other rail to the fuel pressure reg, and -8an line as return line.
2) Slip it with a y block and have two seperated -10an lines going to each fuel rail. Then have 1 line of each fuel rail (be 2 total -10an) going to fuel pressure.
I have mine run with an A 1000 pump. I have 10an from the tank to the filter and pump and all the way up the car to a Y block at the firewall. There it splits into two 8an lines that run to fuel rails and over to the regulator still as two lines. Then a single 6an line runs out the bottom of the reg to the tank as a return line.
