I'd say the Trick Flow setup would be an excellent route to take…as would the AFR 185's. Anything past that though is overkill IMHO. You would start to sacrifice low end grunt for top end h/p…and considering your going to be running around on a stock block, your going to need to keep the rpm's as low as possible for safety sake. Really though, considering there are guys running near 1000rwhp on unported twisted wedge heads…anything head in that range is not going to be a restriction for your setup.
One more thing to keep in mind though is the PTV clearance. Seeing as you already purchased the shortblock, it may simply come down to what fits. The AFR 185's typically need the pistons to be flycut on a stock longblock while the twisted wedge usually clears with ease (cam depending).
