Ordered my SC-Trim Supercharger.
  • Thread starter Thread starter Black-Fifty
  • Start date Start date Feb 11, 2006
Black-Fifty
24
  • Feb 11, 2006
I just purchased a Vortech SC-Trim Supercharger, the 6PSI kit.
Now I heard I can increase the boost by putting a different crank pulley on.
My question is anyone know where I can get one or have a part number?
I know I can just change the pulley on the Charger its self but I dont want to void the waranty.
Any help would be great.
I
IntenseBlue
946
  • Feb 11, 2006
You'll need to go to a larger crank pulley size. Vortech probably offers a larger one. They may only do it on cog systems, though.
Black-Fifty
24
  • Feb 11, 2006
Yeah I know I need one but I cant seem to find one. The biggest I found was a 6.82 on a 6 rib belt.
Rick 91GT
Mustang Master
95
99
PA
Feb 12, 2006
  • Feb 12, 2006
The Sc-Trim still uses the seperate blower belt right? ASP sells lower 1 piece lower pullies in 6" and 7" blower pullies with a underdrive crank pulley.
http://www.aspracing.com/
http://www.aspracing.com/frame.htm
ASP813000
$149.95
You'll pick up about 3 psi with the larger 7" crank.
mustangdaren
605
Hildebran, North Carolina
Feb 12, 2006
  • Feb 12, 2006
You can get the crank pulley you need from www.superchargersonline.com If you are going to up the boost you will also need a larger fuel pump, bigger injectors, BTM, discharge tube with hole for bypass valve and a bypass valve.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
Fuel FMU stuck?
  • JD1964
  • Sep 16, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
JD1964
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
