Ordering my cam, need help asap
  • Thread starter Thread starter Lynx331
  • Start date Start date Oct 16, 2004
L
Lynx331
308
Chicago IL
Oct 16, 2004
  • Oct 16, 2004
Im looking at gettin a trickflow cam. But i have a question, which cam is the stage one cam?
TFS-51402000 Good idle, strong midrange power. Aftermarket intake, heads, and headers recommended. Requires modified mass airflow. Compression ratio: 9:1 to 10.5:1. this one says it needs intake, heads, and headers and modifieid mass air, i have speed density and a cobra intake
TFS-51402001 Fair idle, good midrange power. 2,500 to 3,000 rpm stall converter or five-speed recommended. Compression ratio: 9.5:1 to 11:1.
this one seems like the best choice.....
TFS-51402002 Rough idle, strong top-end power. 3,000 to 3,500 rpm stall converter with 3.90 to 4.11 gears recommended. Compression ratio: 10:1 to 11.5:1. this one is way to radical
what do you guys think? or should i go with a totally different cam?
runningmole
1,127
San Diego, CA
Oct 16, 2004
  • Oct 16, 2004
Probably need a different cam since you're SD. Doesn't Crane make a few SD cams? I believe the 1st came is the Stage 1. Has like .499I and .510E I don't remember the rest
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 16, 2004
  • Oct 16, 2004
If your heads are stock I would suggest something more mild than any of those or leaving the stock cam in there and doing other mods. Stock valve springs float too easily and don't like .500 lift and up. Also the stock heads don't flow too well, and your going to move the powerband up where the engine can't breathe that well.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
