This winter I swapped to an original tach cluster, and all is working well, except the tach itself. The car will not start when it is connected, but the tach is working. When I disconnect the tach ground wire, the car starts, but the tach doesn't work. When I tried to startin it by holding an grounded circuit tester between the coil nad the tach ground wire, the car started and the tachometer worked.
Is there anything inside my tach that might be broke ?
I've got an Pertronix Ignitor in the original distubrator and an accel supercoil.
