I've had a problem, for a few months now, with loosing coolant from my radiator. It seems to purge out of the overflow tank after driving for 30 to 45 minutes and then turning the engine off. I usually check it ever day or 2 and it's usually an inch or 2 below the radiator opening. Yesterday, it ran pretty much dry and of course the engine began to over heat. This morning I filled it up while running and warm. I drove to work about 45 min drive and checked the temp, at different points on the engine, with a infrared thermometer and it was running normal temps at around 176 to 187. It began to purge when the engine was shut down!
Anyone know what could cause it to purge if it is not over heating? Too much pressure build up?
Thanks for any help!
