Over Heating
  • Thread starter Thread starter rgtrough
  • Start date Start date May 31, 2014
R
rgtrough
  • May 31, 2014
Hey guys, new to Mustangs. Just bought my wife a '90 lx convertible 5.0. Serpitine belt self destructed the other day. A previous owner removed the smog pump. I found the sticky with the rotation/belt lengths diagram. The clutch fan rubs on the shroud. Do not know if this is preventing the fan from working properly. will replace the shroud and fan soon. The question FINALLY; is the water pump a reverse flow from what I'm used to? Meaning does the pump turn the same direction as the crank?
Thanks Bud
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 31, 2014
  • May 31, 2014
Yes, the fan rubbing on the shroud is not correct. It is indicative of either a bad fan/clutch, water pump, or worn motor mounts. If it is a HO 5.0 motor and has not been messed with, then you have a reverse rotation water pump. Only way to know is to remove it and the back cover and see the direction of the fins on the back of the impellor shaft.
Your fan is most likely cracked from hitting the shroud. Look for signs of black goop on the bladed or leaking from the center of the fan clutch. To test the fan clutch, when the engine is warm and off the fan should not spin freely- it should bave a noticeable drag on it. If it freewheels then the clutch is bad.
Personally, if you are replacing the fan and clutch, that is an opportune time to replace the mechanical fan with an electric fan setup. I personall like a 1990's V6 Taurus/Contour fan coupled with a flec a lite 33054 variable speed controller. You will also need a new 4g power wire kit, a 4 g ground cable, and a 130amp 3g alternator. You can find the Taurus fan and alternator in most JY . The power wire kit is sold on Ebay or on the Corral. The controller you can get from Summit or LMRS.
As far as overheating, if it is doing it at highway speed then you have an airflow problem such as a clogged radiator. At low rpm or stop and go driving, if it overheats that is usually a water pump or fan. Other culprits could be a defective radiator cap or thermostat. You can rent a pressure tester which will test your cap and for any leaks in the system- radiator, hoses, water pump.
To test the water pump, grab the front of the shaft and see if it wobbles. Also there is a weep hole on the front of the pump and when the bearings go bad water will come out of that hole.
I would strongly recommend you check for sagging or broken motor mounts before doing anything, as the fan hitting the shroud is a tell tale sign. That may fix your problem.
R
rgtrough
  • May 31, 2014
hey Mike, thanks for the quick reply. I am assuming the water pump is good, the car did not overheat until the belt broke and I'm leaning toward the clutch fan failing. Again thanks.
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,076
224
Massachusetts
Jun 2, 2014
  • Jun 2, 2014
Grab the clutch fan with the engine off and give it a spin. It should have resistance and not freewheel much.
A fan that is loose and freewheels is a sign of a bad fan clutch. A clutch that is frozen solid is also bad
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jun 3, 2014
  • Jun 3, 2014
Sounds like bad motor mounts if it is rubbing.
MFE92
1,094
373
124
Phoenix
Jun 4, 2014
  • Jun 4, 2014
3rd the motor mounts
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
  • dan50
  • Jul 18, 2026
dan50
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
