Overdrive VS. Drive
  • Thread starter Thread starter cervinistang
  • Start date Start date Dec 2, 2007
First Prev 2 of 2
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Dec 2, 2007
#21
  • Dec 2, 2007
  • #21
cervinistang said:
you mean put it in overdrive?
and overdirve is only 4th? it doesent sshift from 1,2,3,4?
Shifting from OD to D is like shifting from 4th gear to 3rd in a manual transmission.
With the shifter in D, it will shift 1,2,3.
With the shifter in OD, it will shift 1, 2, 3, 4. If you are in 4th in OD and pull back to D, the trans will drop from 4th to 3rd.
capri debris
289
PA
Dec 2, 2007
#22
  • Dec 2, 2007
  • #22
The original poster is a complete bubble head!!! He doesn't seem to have the gray matter to grasp the concept of O/D... LOL. It has been explained to him clearly and he still can't get it... so just leave him alone. Save your advice for someone who will understand it.
1.8kmint
47
Middletown, CA
Dec 2, 2007
#23
  • Dec 2, 2007
  • #23
I thought overdrive wasnt an actual gear in the trans but like 1/2 a gear involving like a band or something but isnt a real gear but just kinda emulates one to save fuel. Also in overdrive the throttle isnt as quick to respond at least this is how my expirence with it has been. Up until about 40 mph drive and overdrive are at the same rpm however when you get to 55-60 overdrive runs at about 500-600 rpms less...
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Dec 2, 2007
#24
  • Dec 2, 2007
  • #24
Well in the AOD, 4th gear isn't an actual gear. It is a band.
However the term OD is given to any "gear" that has a lower ratio than 1:1.
cervinistang
11
Dearborn, Michigan
Dec 3, 2007
#25
  • Dec 3, 2007
  • #25
thats what i was wondering...
i just got my fox.. i know next to nothing about cars so all this ratio talk is way over my head.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Dec 3, 2007
#26
  • Dec 3, 2007
  • #26
A transmission takes the engines RPMs and either gears it up or down using different sized gears. I assume you know how a gear rotating in sync with another gear works.
With an AOD if you put the car in drive or D you will have the use of 1st gear, 2nd gear, and 3rd gear. Putting the car in overdrive or OD you will have the use of 1st 2nd, 3rd and 4th gear.
The AOD ratios are:
1st = 2.40 : 1
2nd = 1.47 : 1
3rd = 1.00 : 1
4th = 0.67 : 1
Looking at these ratios you can see that all the gears before 3rd are higher numerically than 1. What that means is for every 2.40 revolutions of the motor, the transmission (through the use of gearing) spins the DS one revolution. When you get into 3rd gear or 1 to 1 it does just that, one revolution to one revolution. In overdrive the ratio is lower than 1 to 1, which is considered to be an OVERdrive.
What you seem to be asking is about what the tranny does whether your in D or OD. It does the EXACT same thing. The only difference is in D it will not shift into the 0.67 overdrive gear. Nothing more nothing less.
Sorry for the simple explanation but that might clear some of it up.
foxmustangman
196
Idaho
Dec 3, 2007
#27
  • Dec 3, 2007
  • #27
OH, so that's why my 4th gear is just gone...interesting.
ill advised
656
10
West L.A.
Dec 3, 2007
#28
  • Dec 3, 2007
  • #28
cervinistang you should check out this book. It's a good way to get familiar with the general specs, and some history, on the 5.0.
http://www.amazon.com/Official-Ford...bs_sr_1?ie=UTF8&s=books&qid=1196746986&sr=8-1
There are other, more technical books out there but this one is a good start imo.
First Prev 2 of 2
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
wyatt-tetro891
W
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
