  • SN95 V6 Mustang Tech
Overheating help
  • Thread starter Thread starter HighTech1011
  • Start date Start date Aug 30, 2008
H
HighTech1011
Chesterfield, MI
Aug 30, 2008
  • Aug 30, 2008
I've been having an overheating problem with my GF Mustang for about 3 weeks now. About a month or so ago she blew the upper coolent hose and I replaced that. Now if the car does anything under 45 mph the temp starts rising, and doing anything over 45 the guage just holds steady. Upon closer inspection, I noticed the fan never turning on. Following instructioin in the Hayes manual, traced it back to a bad relay in the CCRM, what the local dealership verified. Replaced the CCRM and it worked fine.
A couple weeks later the dealership my GF bought the car from rewired their GPS into the car, messing with the wiring under the stearing wheel, and a few other places. Now the car is back to its overheating issue, and the fan doesnt turn on for anything, including when the A/C is on. The Fan tests out fine (connected it to the battery and it turns), followed the Hayes manual and everything tests out fine... only tings off is the resistance to ground of the fan (reads 5.8 ohms instand of 5) and both collent temp senders read a little high (withing 10 to 15 ohms) when cool, but read right when at running temp.
I'm at a loss on where to go from here. The dealership claims what they did would have no effect on the car. I thiought someone might be able to shed some light on the topic for me. Her Mustang is a 95 base model, no add-on, no frills. 3.8 L V6, manual trans.
Mustang5L5
Mod Dude
Feb 18, 2001
43,274
17,963
224
Massachusetts
Aug 30, 2008
  • Aug 30, 2008
I can't help much, but you might want to post this in the 1994-1994 V8 forum. The wiring for the fans is the same and there is much more foot traffic there that someone will have an answer for you
Skymarshal
572
Dallas
Aug 30, 2008
  • Aug 30, 2008
Problems with relays and computer logic like that can be maddening and almost impossible to solve. Sometimes the best thing to do is to wire in a new analog sensor (aftermarket temp sensor in the radiator controlling the fan directly through a new relay). It's not fixing the problem, but it bypasses it and gets you back on the road.
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
Nice Sn95. 100k miles. Heirloom. Garage kept. We need some help
  • Jacobn4056.
  • Jan 17, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2024
90sickfox
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
