  • SN95 4.6L Mustang Tech
overheating please help!
  • Thread starter Thread starter venom97
  • Start date Start date Oct 20, 2005
V
venom97
258
Illinois
Oct 20, 2005
  • Oct 20, 2005
my 96 gt was running hot on my way to work last night and on my way home it peged the temp gauge. i had to stop twice. i was thinking it could be a stuck t- stat but when i stopped the fan wasn't running. i jumped the fan and it helped but still was running hot. anyone have this problem?
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Oct 20, 2005
  • Oct 20, 2005
Could be a partially clogged radiator. What is the fluid level in the resivoire and what condition is it in? i.e. dirty, clean. The thermostat is still suspect too. It could be partially stuck open, but usually when a stat goes I think they default to the open position . When the car has cooled (over night) did you remove the radiator cap? Can you see fluid? Sometimes radiators develop small cracks that leak over time (happened with my truck).
V
venom97
258
Illinois
Oct 20, 2005
  • Oct 20, 2005
the coolant is clean and the res. is right where its supposed to be. i did notice some coolant around the cap. i checked the cap and it was tight.
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Oct 20, 2005
  • Oct 20, 2005
You need to check down in the radiator as well. The resivoire is only there for over flow. As for the fan, I'm sure it does have a fuse, either on the panel inside or on the main distribution box under the hood.
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 20, 2005
  • Oct 20, 2005
Same thing (sorta) happened to me a few weeks ago, and today. I was on the highway with the A/C cranked all the way up today and then pulled in to sonic and killed the A/C, but left the car idling. When I went to leave, I noticed either steam or smoke, maybe both, coming from under the hood. I pulled it into a parking spot, let it cool and then filled it up with water. I took it to a shop (highway all the way) and then left it with them to take a look at. They said they couldn't find any leaks anywehre, but that the thermostat might be sticking. I bought a thermostat and a gasket and plan on replacing it tonight. If that doesn't work, only out $10. They also said the fan was kicking on when it needed to, so the fan isn't the problem.
Any ideas? If you need more info, please ask. I provided as much as I figured you need to know
V
venom97
258
Illinois
Oct 20, 2005
  • Oct 20, 2005
let me know if the t-stat fixes the problem for you, i think that where im going to start
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 20, 2005
  • Oct 20, 2005
Will do. I'm letting her cool off in the back right now
twogts4us
4,188
12
79
Dunedin, FL
Oct 20, 2005
  • Oct 20, 2005
Sounds like a hung thermostat.
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 20, 2005
  • Oct 20, 2005
Well, an hour and 10 dollars later...everything seems fine...until I get into traffic. It seems to only happen when I run the A/C. Everything was great, I headed up to Sonic to get some food, idled there WITH the A/C ON and nothing happened. I got back on the highway with the A/C on and then traffic came...we slowed down and my car got to the "AL" in "NORMAL". I killed the A/C, and then got back up to good speeds and everything seemed fine. When I got home, I let it idle for a few minutes with the A/C off, then turned the A/C on and let it idle. No problems.
I'm puzzled to what it could be.
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Oct 21, 2005
#10
  • Oct 21, 2005
  • #10
Possible faulty temperature sensor? Have you tried pulling any codes?
D
Disturbed One
191
#11
  • Oct 21, 2005
  • #11
There might be an intermitent problem with the fan. There was a car that came throught that was having an overheating problem only when she drove without the A/C on. The fan would kick on when she'd have her a/c running but once she'd shut off the a/c the fan would stop also.
FORCED2DV8
458
Grand Rapids MI
Oct 21, 2005
#12
  • Oct 21, 2005
  • #12
It always runs hotter when the a/c is on, I switched to a lower thermostat 180. and wired the fan so it comes on sooner, i have had no problems since.
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
C
Fuse help please. 73 Mach 1
  • Curtis Harper
  • Oct 19, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 28, 2026
Curtis Harper
C
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
