Overheating Problems
  • Thread starter Thread starter Strype
  • Start date Start date Sep 4, 2007
First Prev 2 of 2
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 5, 2007
#21
  • Sep 5, 2007
  • #21
How do you multi-quote like you did??
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Sep 5, 2007
#22
  • Sep 5, 2007
  • #22
See the little box next to the "Quote" button? Check each that you want and then quote the last one
D
dagmando
14
Northern Illinois
Sep 5, 2007
#23
  • Sep 5, 2007
  • #23
210-215 is not overheating and is actually perfectly normal for after idling for 15 minutes. 15 minutes is a long time. You're fine.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Sep 5, 2007
#24
  • Sep 5, 2007
  • #24
Seriously?
That's what my neighbor said. Is that about what they idled at from the factory?
D
dagmando
14
Northern Illinois
Sep 5, 2007
#25
  • Sep 5, 2007
  • #25
I not know what the factory spec is, if there is one, but personally would not be concerned until 240*+ and it's a problem when it starts to overflow.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Sep 5, 2007
#26
  • Sep 5, 2007
  • #26
My neighbor told me to expect the temp to climb when I had the A/C on.
HISSIN50
34
129
Sep 5, 2007
#27
  • Sep 5, 2007
  • #27
Some parameters from Ford. The puter starts pulling timing at about 226*F and IIRC, it shuts the AC off at 242*F.
94-95 fans have low speed come on/off at 208/200*F. High is 226/220*F ( ). You can make some inferences about what was deemed acceptable from those specs.
Those temps are nice for economy and emissions but not for our old stangs, nor aluminum heads. Nor is it really idea if running a 180* t-stat in an effort to phase shift all operating temps (across the board).
Optimal coolant temps are 190-210*F. I hate seeing more than 195*F personally (partly because I like lots of fudge factor when it's 115*F outside).
FWIW, a HD fan clutch and metal repalcement fan blade work well (what I run on the fox. Poop Dawg is the only guy I can think of whom had issue with this set-up for some reason). However, you're in over 100 beans for both. For that money, you could get the Taurus fan working with a good controller that shouldn't crap its pants (unless your fan motor was really resistive and that was why you were melting wires).
Have you ever tried letting it idle. Then put a huge box fan (or one of those contractor fans with the slit-sized discharge nozzle) in front of the opening(s) in front of the car? If it stays cooler like this, you know you have a fan issue.
Good luck bud. You're like the Bottomlesspit (Ken) of cooling fan issues.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Sep 5, 2007
#28
  • Sep 5, 2007
  • #28
It cooled back down to about 195-200 when I drove it down the street. So I'm thinking I'm having having the WORST LUCK in Stangnet history from fans
I dunno what to do.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Sep 5, 2007
#29
  • Sep 5, 2007
  • #29
Thoughts...
1) Usually my buddies cars run significantly cooler than mine. None of them have working A/C and thus the condensor is gone.
2) The efan will cause me to have to purchase a 3G alternator and a DCC controller- I know someone gave me some schematics on how to set up a light to tell if the fan is off or on. It'll take me a long time to buy this stuff.
3) I'm still utterly lost as to how the wires melted on the fan. I think I'll copy my friend's set up, except I'll use a DCC controller. Maybe the car won't catch fire if the wires melt again.
4) I have a 16" (i think) flex fan I was using, but the spacer for it kept it short of getting all the way into the shroud. I bought a longer spacer so maybe that would work. If the flex fan was closer to the radiator and more "inside" the fan shroud.
302RollinHard
Columbus, OH
Sep 5, 2007
#30
  • Sep 5, 2007
  • #30
too small of a wire will cause them to melt. What size wire were you running on the taurus fan??? Wires heating up means resistance IE either bad ground, bad motor or too small of a wire. I used 14 ga on my taurus fan and it was too small. Had to move to 10 gauge. This was with it connected directly to the battery.
HISSIN50
34
129
Sep 5, 2007
#31
  • Sep 5, 2007
  • #31
If you dont have your AC turned on, so long as the condenser is pretty clear of debris it should matter not.
If you go with the Delta controller, Brian has his progressive LED which works well. If you just need to rig this up, an LED of your own can be used.
I can't remember but I thought your wires might have been on the small side. Following the above advice with the 10 AWG wiring on the load side and 18 for the control side should have you covered.
You want the middle of a given fan blade to be under the outer edge of the shroud (half covered, half exposed). Getting the fan oriented with regard to the shroud is pretty important.
It still totally sounds like a fan issue since it cooled back down once you started moving. I'd pick a fan control means and stick with it and get it done right. Unfortunately each of your set-ups has had a lacking element, so the all kinda suck.
For diagnostics, if you can do it without torching anything you could hard wire the Taurus fan in - just for a testing session to see if it would otherwise fix your issue. If so, you know that with proper fan control and wiring gauge, you should be set. If you do this, use FUSED 10 or 8 AWG wires.
Good luck.
twistedwankel
200
Spring Hill, FL
Sep 6, 2007
#32
  • Sep 6, 2007
  • #32
I agree.
twistedwankel
200
Spring Hill, FL
Sep 6, 2007
#33
  • Sep 6, 2007
  • #33
I agree. Also as a little aside to that. My 84 conv. with 86 driveline has what I believe to be the original radiator as I put some sealant in it over a year and 1/2 ago to stop the leaks and it's held ever since so I haven't replaced it yet.
I live in FL and it's consistently 90F with high humidity.
I also have to cool the AOD with this old 2 pass radiator with original mechanical clutch fan.
When it's 95F out with the AC off (no matter what) the temp is 1/2 to 5/8th max. I don't have degrees on the factory gage. It just has a safe range is all.
When I turn on the AC max and run for 15 minutes being a conv with no roof insulation and an automatic putting out heat eventually in traffic start and stop slowly the gage will raise to 3/4+max. and pretty much stays at 3/4 for as long as I run the AC no matter what speed I go. Note that the radiator doesn't overflow more than normal expansion. Within 5 minutes of turning off the AC the temp drops back to 1/2-5/8 like always. It's been this way for years so I don't get concerned about it.
One day I might consider to get the 3 pass radiator? I know the one I put on my race mustang with lots of HP never overheated EVER but it didn't have AC or an automatic either.
You should check the temp with a good gage or meter as the factory stuff isn't all that accurate. About all you can rely on from a factory gage is repeatability so you know what the norm is.
My 96 Dodge truck with a towing package and trans cooler has always run at 220 by the gage with a 195 stat in it. Climbs slightly at 70mph hauling a car trailer up hills.
So like the man said. Don't worry about it.
My 21 yr old son just got an 02 WRX and he loves it. Zero to 60 is insanely fast stock and it sticks like glue. Tons of aftermarket toys for it. You should only keep a car you like as you will begrudge any money it costs you otherwise and you won't do important things to it out of joy.
My 61 years of cents. A car should be fun to drive.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Sep 6, 2007
#34
  • Sep 6, 2007
  • #34
Thanks guys ^^^
It was the actual FAN WIRES that melted and they are thick though I did use a smaller wire leading up to it- 12-14 I think. The controller had really small wire on it.
I'll probably go ahead and do the swap- I'll flush it, I'll replace the pump and of course head gaskets when I do the swap. I'll put the taurus fan back on with fused wire.
If I get a new job and haven't done the swap yet, I will probably go ahead and buy a WRX
I dunno, this car is just pissing me off. Maybe I'll feel different when I can drive it without worrying
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Jan 14, 2008
#35
  • Jan 14, 2008
  • #35
UPDATE:
As some of you know I've had a PLETHORA of overheating problems. So my 93 Coupe has sat literally for months, like almost a year.
So when it was figured out that the backwash of air from the fan was causing my MAF to screw up (due to running a short cold air intake with exposed filter), I put the stock clutch fan back on and put the factory airbox back on. It still overheated. So I was toying with the idea of selling the car.
Well I cleaned out my garage last weekend and found a brand new $70 clutch fan that I didn't know I had. So I switched them out and drove the car in 50 degree weather all day almost. I went through almost a tank of gas and the car never once got over 150 degrees!
So I am calling this a closed case, at least until I test it out in 90 degree weather again.
Glad to have my car back!
I'm posting this in both of my threads to tie them off for SEARCH purposes. Hope it helps someone else.
First Prev 2 of 2
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
F
Overheating after ECU flash
  • fourtyfour338
  • Jul 23, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 23, 2025
