  • 1994 - 1995 Specific Tech
Overheating.
  • Thread starter Thread starter Guero
  • Start date Start date Mar 17, 2007
Guero
2,148
Mar 17, 2007
  • Mar 17, 2007
Well my car has been overheating this last couple of days. Just cruising, and on the freeway. Fan works. What can it be. I did notice that the radiator hose is soft instead of being full of pressure. Im hoping its the thermstat or the radiotor cap. ANy ideas? Im broke right now so i cant buy both Wait i take that back i have a 160 t-stat, but is that to low??? I live in Phoenix which gets hot. but not right now
HISSIN50
34
129
Mar 17, 2007
  • Mar 17, 2007
Guero, it was 99* in Phx today - that's pretty hot.
Can you narrow it down at all? Like does it cool off once you get on the highway. Or does it cool off once you drive slow or are stopped in traffic?
Have you changed the fan thresholds with your TwEECer? I'd get that high speed fan coming on a lot earlier than stock if you havent.
Coolant level is okay?
If you don't use them, when you swap stat's I would not bother with anything but a Mr Gasket (or other performance) t-stat. I lowered avg operating temps ~ 8*F by just changing the stat (going from a new parts store 180, which takes forever to open and doesnt flow worth a crap, to a Mr G 180*). 10 bucks at your local speed shop.
You don't know what temp you're reading, do ya? Are both fan speeds coming on, and at the right temps?
Random thoughts/questions.
Good luck bud.
Guero
2,148
Mar 17, 2007
  • Mar 17, 2007
At night it wasn't that hot. But i would understand if it got hot if i was semi palying with it, but i wasn't. It was just hot all way aroung highway, low speeds. Whats weird is the hose does not have any pressure. Shouldn't it have pressure when i turn of the car?????
HISSIN50
34
129
Mar 17, 2007
  • Mar 17, 2007
Getting back to cooling systems..............
The upper hose won't necessarily be firm. Do you have access to a cooling system pressure tester? You can pump it up and confirm that it's holding pressure. The difference in no pressure and 16 PSI (what your cap should be rated for) is ~48*F above the boiling point of a 50/50 mix of E/G coolant and water.
All that said, toss a new stat on and see if the hose gets firmer - as you're postulating, the t-stat might not be flowing as decently as it otherwise could. Your lower rad hose could also collapse at higher RPM's if there's no spring in it and the t-stat isnt opening all the way.
Good luck bud.
Guero
2,148
Mar 17, 2007
  • Mar 17, 2007
i was a little ify if i should right that part lol!!! You had to catch you pervert
The spring is in there. ll go buy a mr gaket one right now. This also just happened, so im guesiin the month in the garage sit kinda messed up the t-stat
Guero
2,148
Mar 17, 2007
  • Mar 17, 2007
Well i changed it. and it doesn't heat up. But its not as hot as yesterday either. Maybe its time for a fluidyne radiotar.
HISSIN50
34
129
Mar 17, 2007
  • Mar 17, 2007
A nice new radiator is always cool but you might be ok for awhile. When it gets up to 115* for 40 days in a row, you'll know better. That's always a fun time to fabricate things anyhow.
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
