  • 1994 - 1995 Specific Tech
Overheating
  • Thread starter Thread starter Dark_Pony94
  • Start date Start date Mar 2, 2009
D
Dark_Pony94
36
  • Mar 2, 2009
Hey guys I'm hoping that you can help me out. My car is overheating. It's fine at idle till it gets driven then spikes to the L and above. At first I thought it was the waterpump because it was leaking. I've replaced that as well as the thermostat because I thought it was bad too. At first the coolant wasnt circulating thats why I changed out the tstat. Now it is going through. I took it for a quick spin and it doesnt seem to be down on power so I dont believe its the headgasket. No fluids appear to be leaking anywhere to me. Also when the car is on L and above I turned on the heater and it blew cold. So possibly the heater core is bad? I wouldnt think that would have anything to do with the overheating though. One last thing is I put stop leak in the radiator sometime last year and this problem started well after that. Any thoughts?
F
fordtech28
312
Riverside Cali.
Mar 2, 2009
  • Mar 2, 2009
Is the fan turning on ?? Also it might be that your radiator is clogged up how old is it
Adam95GT
2,564
Burlington, NJ
Mar 2, 2009
  • Mar 2, 2009
id think its a clogged heatercore... look on the pass side of your engine bay on the firewall there is a little tap like thing.. when my core went it was leaking from there also check your pass floor boards
D
Dark_Pony94
36
  • Mar 2, 2009
Yes the fan is turning on.
The floorboards didn't seem wet when I was in it. Will check again just to make sure. But would a heater core make it overheat?
fastgtfairlane
266
  • Mar 2, 2009
i think you have air in the system. try to burp it out. run the car with the cap off and let the tstat open up. having an air bubble in the system can cause the car to over heat as well as cause no heat from the vents. you could also take the hoses going to the heater core and run water from a water hose through and flush the heater core out.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 2, 2009
  • Mar 2, 2009
I also think it's an air pocket. Toss the front end on jackstands so the cap is the highest point in the system, remove the cap, and let it come up to operating temperature. Once coolant starts to flow, give the upper hose a few squeezes and watch for the level in the radiator to drop.
D
Dark_Pony94
36
  • Mar 3, 2009
thanks guys I'll give that a shot tonight and report back. Also do you guys know if a fox radiator will fit an sn95?
D
Dark_Pony94
36
  • Mar 3, 2009
Thank you fastgtfairlane and StangGT95 you guys were right with an air bubble. She's burped and took it out for a WOT run and it didnt budge from R
fastgtfairlane
266
  • Mar 3, 2009
good deal, glad u got it fixed
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
2001 SVT Cobra Overheating Issue
  • bradencaron0
  • May 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
V
Engine Coolant Leaking?
  • vinzo
  • Jan 26, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
