Oxygen Sensor Removal??
Quick Pony
129
Pensacola, Florida
Visit site
I bought 2 oxygen sensors for my 1991 LX, 5.0 convertible. I removed the old sensor on the driver's side and put the new one in, which took about 3 minutes.
The passenger side sensor is another story. I have tried for 2 days to remove it, with no success!! I have the special socket and I'm getting a good grip on the old one, it just won't budge. I have used PB Blaster lubricant on it, hit it with a hammer, still nothing. :mad:
Anybody have any tricks up their sleeve?
I have to replace it because the old one's wires are torn up.
What will happen if I drive the car with one new oxygen sensor and the other one
disconnected? :shrug:
Thanks
Larry
  • Sponsors(?)
BlownFiveLiter
have car, will race....wait, it doesn't run
18
88
Chicagoland
Hit the bung with a propane torch and get it nice and hot. Spray it with some type of penetrating oil while it's hot, and it will draw the cool oil into the threads. Yes, it will smoke to high hell and smell like a barbecue grill, but it works. It'll still take some effort to remove, but it'll be a lot easier than just fighting with it using the socket and oil.
5.0 Nostalgia
897
CT
I just use a 7/8 wrench. If it's too tight, I just tap it. Unless you are using a breaker bar, the wrench will give you more leverage. I agree with the propane torch though, just be careful.
89-347-LX
38
Oklahoma
i had to use a small pipe wrench on mine and just keep loading it down with DW-40 and it finally came out but with hassle on every turn
Quick Pony
129
Pensacola, Florida
Visit site
Hey Matt,
Thanks for the reply. I was thinking the same thing about a torch, but unfortunately I don't have one. I thought there my be another method of removal that I had overlooked.
I just drove the car to the gas station to fill up and it runs pretty good with only 1 oxygen sensor working, but when I stop at a traffic light, its idle is erratic.
I've have never had such a problem removing a part in my entire life!!!!
Thanks again
Larry
BlownFiveLiter
18
88
Chicagoland
You might be able to get away without a torch if you try it while the exhaust it hot from driving. I picked up a propane torch for like $10 from the local Ace Hardware in town by me. One word of caution though, your entire exhaust system is going to be damn hot if you do it after driving, versus just the one area when using the torch.
HISSIN50
SN Certified Technician
28
129
7/8" box end wrench and a 4# hammer (beating on the other end of the wrench). The shocking from the hammer-blows is like an impact wrench.
Good luck.
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,294
9,415
224
Massachusetts
Good luck.
I was going to buy an impact gun until i discovered that method. never had a problem with a bolt that that method couldn't free
90bluegt
592
I just use a wrench with another wrench hooked into it, plus the end of my jack (it's removable with a good size hole) and PB-Blast. That usually works..
Thread starter Similar threads Forum Replies Date
M Removing Oxygen Sensor Questions 1994 - 1995 Specific Tech 3
D Oxygen sensor 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
D **HELP NEEDED** O2 PIGTAIL WIRES 1996 - 2004 SN95 Mustang -General/Talk- 2
D O2 sensor harness 1994 - 1995 Specific Tech 0
D Oxygen sensor help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Onesick99GT Exhaust Wideband Oxygen Sensors Help Needed SN95 4.6L Mustang Tech 8
K Help P1151 SN95 V6 Mustang Tech 1
fredfifty Exhaust Leak At O2 Bung Fox 5.0 Mustang Tech 33
A Plesae Help With Oxygen Sensor Sorting Out Fox 5.0 Mustang Tech 6
D Emissions Problem - Very High Hc Fox 5.0 Mustang Tech 35
T Please Help O2 Sensor Hookup 5.0 Swap 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
T Engine 2005 V6 Oxygen Sensor / Cel Problem 2005 - 2009 Specific Tech 0
Blown88GT For Sale 2 Bosch Oxygen Sensors, Nib Engine and Power Adder 3
des89stang SOLD 87-93 Denso Oxygen Sensors, Nib. Other Classifieds 4
Luis911 Electrical I Had Code 92, Exchanged Oxygen Sensors, Now Code 42 (update Now Code 44 And 94) Fox 5.0 Mustang Tech 7
Blown88GT SOLD 2 Bosch Oxygen Sensors, Nib Engine and Power Adder 11
L Changing Front Oxygen Sensors SN95 4.6L Mustang Tech 5
L Oxygen Sensor Clean Up SN95 4.6L Mustang Tech 0
Luis911 Engine Useful Life Of The Oxygen Sensor Fox 5.0 Mustang Tech 6
J 95 3.6L V6- Oxygen Sensor SN95 V6 Mustang Tech 3
8 oxygen sensor socket SN95 4.6L Mustang Tech 5
93lxtwin Oxygen sensors Fox 5.0 Mustang Tech 9
90silverstang Running Rich,A9M ECU and Oxygen Sensor question Fox 5.0 Mustang Tech 13
arnie93lx 87-93 M/T oxygen sensor harness Engine and Power Adder 1
R WILL 2001 gt oxygen sensors work in my 96 GT SN95 4.6L Mustang Tech 1
Tripoli Upstream Oxygen Sensors - On with open loop tune? SN95 4.6L Mustang Tech 8
I upstream vs downstream oxygen sensor 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
hollywoodstang oxygen sensors and off-road H pipe 1994 - 1995 Specific Tech 16
J oxygen sensors SN95 4.6L Mustang Tech 5
M 99 cobra oxygen sensor harness SVT Tech Forum 2
FoxRod87 oxygen sensors SN95 4.6L Mustang Tech 5
Hi-Po Oxygen sensors - Code 41 Fox 5.0 Mustang Tech 2
babybudistmonk Oxygen Sensors 2.3L (N/A & Turbo) Tech 3
M oxygen sensor wiring-92 2.3L (N/A & Turbo) Tech 2
tx65coupe 1997 Cobra Oxygen Sensors SVT Tech Forum 2
C Tell Me If I'm Crazy. Oxygen Sensors SN95 4.6L Mustang Tech 17
V oxygen sensors question on a 97 4.6L V8 SOHC -which one goes where? SN95 4.6L Mustang Tech 0
V oxygen sensors on a 97 4.6L V8 SOHC -which one goes where? 1996 - 2004 SN95 Mustang -General/Talk- 2
blackstangt 4th wire on oxygen sensor harness. Fox 5.0 Mustang Tech 2
G oxygen sensor??? Fox 5.0 Mustang Tech 6
Blk91stang Checking Power to Oxygen Sensors?? How?? Fox 5.0 Mustang Tech 2
N Oxygen sensor question Fox 5.0 Mustang Tech 10
Chowder Head Does anyone have experience with this oxygen sensor kit? Fox 5.0 Mustang Tech 3
Quick Pony Oxygen Sensors ? Fox 5.0 Mustang Tech 3
chr1s11575stang Oxygen Sensors??? Fox 5.0 Mustang Tech 9
I Installed BBK longtube headers and engine runs better without oxygen sensors!!! Fox 5.0 Mustang Tech 8
Dean85GT Oxygen sensor bung thread size? Fox 5.0 Mustang Tech 2
P Oxygen Sensor Wires Backwards? Classic Mustang Specific Tech 3
stevesLX oxygen sensor wiring Fox 5.0 Mustang Tech 6
F Oxygen Sensor Signal Wire Fox 5.0 Mustang Tech 5
