Oxygen Sensors ?
Quick Pony
129
Pensacola, Florida
Visit site
I understand there are 2 oxgen sensors for a 1991 LX 5.0 Convertible. Do both sensors have to be replaced at the same time, or can you just replace one?
Are all oxygen sensors at the autoparts stores about the same? :shrug:
Which oxygen sensor do you consider the best to use for Mustangs?
Thanks
Larry :flag:
  • Sponsors(?)
HISSIN50
SN Certified Technician
28
129
If you're replacing them because of a service interval, then you'd do both.
If one failed or became contaminated prematurely, I see no reason why you cannot replace just it. Just make a notation in your service records so you remember they're staggered and which is which.
Ford or Bosch sensors work well.
Good luck Larry.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Visit site
Yep, JT is right on...:)
There are two sensors, one on Bank 1 (passenger side) and one on Bank 2 (driver side).
I believe most autoparts stores carry Bosch. I have replaced a few on my past cars and did not have any problems with them. They were running in the $80 range.
7/8" open-end wrench should remove them for you...
You can replace one at a time with no worries if one is malfunctioning.
Most places say to change them every 100,000 miles I believe.
Thread starter Similar threads Forum Replies Date
D Oxygen sensor 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
D **HELP NEEDED** O2 PIGTAIL WIRES 1996 - 2004 SN95 Mustang -General/Talk- 2
D O2 sensor harness 1994 - 1995 Specific Tech 0
D Oxygen sensor help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Onesick99GT Exhaust Wideband Oxygen Sensors Help Needed SN95 4.6L Mustang Tech 8
K Help P1151 SN95 V6 Mustang Tech 1
fredfifty Exhaust Leak At O2 Bung Fox 5.0 Mustang Tech 33
A Plesae Help With Oxygen Sensor Sorting Out Fox 5.0 Mustang Tech 6
D Emissions Problem - Very High Hc Fox 5.0 Mustang Tech 35
T Please Help O2 Sensor Hookup 5.0 Swap 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
T Engine 2005 V6 Oxygen Sensor / Cel Problem 2005 - 2009 Specific Tech 0
Blown88GT For Sale 2 Bosch Oxygen Sensors, Nib Engine and Power Adder 3
des89stang SOLD 87-93 Denso Oxygen Sensors, Nib. Other Classifieds 4
Luis911 Electrical I Had Code 92, Exchanged Oxygen Sensors, Now Code 42 (update Now Code 44 And 94) Fox 5.0 Mustang Tech 7
Blown88GT SOLD 2 Bosch Oxygen Sensors, Nib Engine and Power Adder 11
L Changing Front Oxygen Sensors SN95 4.6L Mustang Tech 5
L Oxygen Sensor Clean Up SN95 4.6L Mustang Tech 0
Luis911 Engine Useful Life Of The Oxygen Sensor Fox 5.0 Mustang Tech 6
M Removing Oxygen Sensor Questions 1994 - 1995 Specific Tech 3
J 95 3.6L V6- Oxygen Sensor SN95 V6 Mustang Tech 3
8 oxygen sensor socket SN95 4.6L Mustang Tech 5
93lxtwin Oxygen sensors Fox 5.0 Mustang Tech 9
90silverstang Running Rich,A9M ECU and Oxygen Sensor question Fox 5.0 Mustang Tech 13
arnie93lx 87-93 M/T oxygen sensor harness Engine and Power Adder 1
R WILL 2001 gt oxygen sensors work in my 96 GT SN95 4.6L Mustang Tech 1
Tripoli Upstream Oxygen Sensors - On with open loop tune? SN95 4.6L Mustang Tech 8
I upstream vs downstream oxygen sensor 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
hollywoodstang oxygen sensors and off-road H pipe 1994 - 1995 Specific Tech 16
J oxygen sensors SN95 4.6L Mustang Tech 5
M 99 cobra oxygen sensor harness SVT Tech Forum 2
FoxRod87 oxygen sensors SN95 4.6L Mustang Tech 5
Hi-Po Oxygen sensors - Code 41 Fox 5.0 Mustang Tech 2
babybudistmonk Oxygen Sensors 2.3L (N/A & Turbo) Tech 3
M oxygen sensor wiring-92 2.3L (N/A & Turbo) Tech 2
tx65coupe 1997 Cobra Oxygen Sensors SVT Tech Forum 2
C Tell Me If I'm Crazy. Oxygen Sensors SN95 4.6L Mustang Tech 17
V oxygen sensors question on a 97 4.6L V8 SOHC -which one goes where? SN95 4.6L Mustang Tech 0
V oxygen sensors on a 97 4.6L V8 SOHC -which one goes where? 1996 - 2004 SN95 Mustang -General/Talk- 2
blackstangt 4th wire on oxygen sensor harness. Fox 5.0 Mustang Tech 2
G oxygen sensor??? Fox 5.0 Mustang Tech 6
Blk91stang Checking Power to Oxygen Sensors?? How?? Fox 5.0 Mustang Tech 2
N Oxygen sensor question Fox 5.0 Mustang Tech 10
Quick Pony Oxygen Sensor Removal?? Fox 5.0 Mustang Tech 10
Chowder Head Does anyone have experience with this oxygen sensor kit? Fox 5.0 Mustang Tech 3
chr1s11575stang Oxygen Sensors??? Fox 5.0 Mustang Tech 9
I Installed BBK longtube headers and engine runs better without oxygen sensors!!! Fox 5.0 Mustang Tech 8
Dean85GT Oxygen sensor bung thread size? Fox 5.0 Mustang Tech 2
P Oxygen Sensor Wires Backwards? Classic Mustang Specific Tech 3
stevesLX oxygen sensor wiring Fox 5.0 Mustang Tech 6
F Oxygen Sensor Signal Wire Fox 5.0 Mustang Tech 5
